Subject: Re: epicsqt: getting started questions [DLM=For-Official-Use-Only]
From: "CLIFT, Mark via Tech-talk" <[email protected]>
Date: Wed, 15 Apr 2020 02:07:19 +0000
Hi John,
I see a couple of issues in your environment.
  1.  Change QWT_INLCUDE_PATH=/nfs/opt/qwt-6.1.3.sl7/include to
                    QWT_INCLUDE_PATH=/nfs/opt/qwt-6.1.3.sl7/include
  2. Change QT_PLUGIN_PATH=/nfs/chess/user/jad22/epics/qt/qeframework/lib/linux-x86_64/designer to
                         On my system qt/qeframework/lib/linux-x86_64 contains libQEFramework.so
                          and, qt/qeframework/lib/linux-x86_64/designer contains libQEPlugin.so
        3.  To test load "designer &" and scroll down the widget box in the left frame and look for the EPICSQt widgets.
Thank you also for the bug report on the Galil driver.  I'll fix the issue reported in the github repository soon.
Kind regards,
Prev: Re: Galil device support - static build Ben Franksen via Tech-talk
Next: Using CP in PV links vs. routing Hinko Kocevar via Tech-talk
Prev: EPICS Puppet module v2.0 available Konrad, Martin via Tech-talk
