Subject: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter
From: Carsten Winkler via Tech-talk <[email protected]>
To: <[email protected]>
Date: Wed, 6 May 2020 16:22:11 +0200
I successfully compiled Epics 7.0.3.1 for Windows 7 x64. When I start softIoc.exe without dbd-parameter (-D), everything is fine. But when I specify the path for the same dbd file, I get an illegal option error.
(I wanna move the dbd file for a client application.)
What do I wrong?
Best regards
Carsten
C:\>"C:\base-7.0.3.1\bin\windows-x64\softIoc.exe" -D "C:\base-7.0.3.1\dbd\softIoc.dbd" -d "\DemoIOC\db\demo.db"
C:\base-7.0.3.1\bin\windows-x64\softIoc.exe: illegal option -- D
Usage: C:\base-7.0.3.1\bin\windows-x64\softIoc.exe [-D softIoc.dbd] [-h] [-S] [-s] [-a ascf]
[-m macro=value,macro2=value2] [-d file.db]
[-x prefix] [st.cmd]
    -D <dbd>  If used, must come first. Specify the path to the softIoc.dbdfile.        The compile-time install location is saved in the binary as a default.
    -h  Print this mesage and exit.
    -S  Prevents an interactive shell being started.
    -s  Previously caused a shell to be started.  Now accepted and ignored.
    -a <acf>  Access Security configuration file.  Macro substitution is
        performed.
    -m <MAC>=<value>,... Set/replace macro definitions used by subsequent -d and
        -a.
    -d <db>  Load records from file (dbLoadRecords).  Macro substitution is
        performed.
    -x <prefix>  Load softIocExit.db.  Provides a record "<prefix>:exit".
        Put 0 to exit with success, or non-zero to exit with an error.
Any number of -m and -d arguments can be interspersed; the macros are applied
to the following .db files.  Each later -m option causes earlier macros to be
discarded.
A st.cmd file is optional.  If any databases were loaded the st.cmd file will
be run *after* iocInit.  To perform iocsh commands before iocInit, all database
loading must be performed by the script itself, or by the user from the
interactive IOC shell.
Compiled-in path to softIoc.dbd is:
        C:\base-7.0.3.1\bin\windows-x64\../../dbd/softIoc.dbd
Unknown argument: -?
C:\>
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Michael Davidsaver via Tech-talk
Prev: EPICS DB file automation for PLC from spreadsheet Shen, Guobao via Tech-talk
Next: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Michael Davidsaver via Tech-talk
Prev: Re: EPICS DB file automation for PLC from spreadsheet Lucas Russo via Tech-talk
