1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Carsten Winkler <[email protected]>
Cc: [email protected]
Date: Wed, 6 May 2020 10:15:06 -0700
On 5/6/20 7:22 AM, Carsten Winkler via Tech-talk wrote:
> Hi,
> I successfully compiled Epics 7.0.3.1 for Windows 7 x64. When I start softIoc.exe without dbd-parameter (-D), everything is fine. But when I specify the path for the same dbd file, I get an illegal option error.
> (I wanna move the dbd file for a client application.)
> What do I wrong?
Nothing.  The bad news is that this was a mistake with 7.0.3.1
which has since been fixed.  The good news is that -D is no longer needed
to find softIoc.dbd in its default location ../../dbd/softIoc.dbd
relative to softIoc.exe.  So in your example you should be able to omit '-D'.
https://epics.anl.gov/tech-talk/2019/msg01822.php
> Best regards
> Carsten
> C:\>"C:\base-7.0.3.1\bin\windows-x64\softIoc.exe" -D "C:\base-7.0.3.1\dbd\softIoc.dbd" -d "\DemoIOC\db\demo.db"
> *C:\base-7.0.3.1\bin\windows-x64\softIoc.exe: illegal option -- D*
> Usage: C:\base-7.0.3.1\bin\windows-x64\softIoc.exe [-D softIoc.dbd] [-h] [-S] [-s] [-a ascf]
> [-m macro=value,macro2=value2] [-d file.db]
> [-x prefix] [st.cmd]
>     -D <dbd>  If used, must come first. Specify the path to the softIoc.dbdfile.        The compile-time install location is saved in the binary as a default.
>     -h  Print this mesage and exit.
>     -S  Prevents an interactive shell being started.
>     -s  Previously caused a shell to be started.  Now accepted and ignored.
>     -a <acf>  Access Security configuration file.  Macro substitution is
>         performed.
>     -m <MAC>=<value>,... Set/replace macro definitions used by subsequent -d and
>         -a.
>     -d <db>  Load records from file (dbLoadRecords).  Macro substitution is
>         performed.
>     -x <prefix>  Load softIocExit.db.  Provides a record "<prefix>:exit".
>         Put 0 to exit with success, or non-zero to exit with an error.
> Any number of -m and -d arguments can be interspersed; the macros are applied
> to the following .db files.  Each later -m option causes earlier macros to be
> discarded.
> A st.cmd file is optional.  If any databases were loaded the st.cmd file will
> be run *after* iocInit.  To perform iocsh commands before iocInit, all database
> loading must be performed by the script itself, or by the user from the
> interactive IOC shell.
> Compiled-in path to softIoc.dbd is:
>         C:\base-7.0.3.1\bin\windows-x64\../../dbd/softIoc.dbd
> Unknown argument: -?
> C:\>
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Johnson, Andrew N. via Tech-talk
Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Prev: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Carsten Winkler via Tech-talk
Next: Re: Epics 7.0.3.1 Windows x64 softIOC - illegal dbd parameter Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
