Subject: Re: [EXTERNAL] Phoebus-color.def & font.def are not effictive
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>, 白丹萍 <[email protected]>
Date: Mon, 11 May 2020 12:18:50 +0000
Hi:
> I reset the color.def and font.def  documents,  but they are not effictive. What might be the reason?
Check the online help, also available from https://control-system-studio.readthedocs.io/en/latest/.
Look for the display builder preference settings, https://control-system-studio.readthedocs.io/en/latest/preference_properties.html
# Package org.csstudio.display.builder.model
# Named colors
# One or more *.def files, separated by ';'
# Defaults to built-in copy of examples/color.def
color_files=examples:color.def
==> By default, it's using a built-in copy for the color settings.
If you create your own color.def file, and starting with the one from the examples is certainly a good idea, you then need to configure the tool to use your file.
Read the 'Preferences' section in the help to see how to do that, https://control-system-studio.readthedocs.io/en/latest/preferences.html
For example, add this to your settings file:
org.csstudio.display.builder.model/color_files=/the/path/to/my/color.def
and then start the tool with `-settings /path/to/your/settings.ini
You can see the list of effective settings via the menu Help, About. The Details pane includes a tab that lists all preference settings in the same format that is used by the settings.ini file.
-Kay
Phoebus-color.def & font.def are not effictive 白丹萍 via Tech-talk
Prev: Re: StreamDevice: Timeout after reading 27 bytes Mark Rivers via Tech-talk
Next: Using Jupyter notebooks for controlling experiments Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Prev: Phoebus-color.def & font.def are not effictive 白丹萍 via Tech-talk
Next: 回复:Phoebus-color.def & font.def are not effictive 白丹萍 via Tech-talk
