Thank you Jarda!! I've been banging my head on this for a couple of days now. Below is a complete working ioc. Paul PYTHON FILE =========== #!/usr/local/epics/modules/pythonIoc/pythonIoc import numpy as npfrom softioc import builder, softioc import pandas d = {'col1': [1, 2], 'col2': [3, 4]} x = pandas.DataFrame(d) x_string = x.to_string() a_PV = builder.WaveformOut("name",length=len(x_string),FTVL="CHAR") a_PV.set(np.array([ord(i) for i in x_string])) print(a_PV.get().tostring()) builder.LoadDatabase() softioc.iocInit() softioc.interactive_ioc(globals()) caQtDM FILE =========== <?xml version="1.0" encoding="UTF-8"?> <ui version="4.0"> <class>Form</class> <widget class="caFrame" name="Form"> <property name="geometry"> <rect> <x>0</x> <y>0</y> <width>400</width> <height>300</height> </rect> </property> <property name="windowTitle"> <string>Form</string> </property> <widget class="caMultiLineString" name="camultilinestring"> <property name="geometry"> <rect> <x>30</x> <y>30</y> <width>311</width> <height>191</height> </rect> </property> <property name="channel" stdset="0"> <string notr="true">name</string> </property> </widget> </widget> <customwidgets> <customwidget> <class>caFrame</class> <extends>QFrame</extends> <header>caFrame</header> <container>1</container> </customwidget> <customwidget> <class>caMultiLineString</class> <extends>QPlainTextEdit</extends> <header>caMultiLineString</header> </customwidget> </customwidgets> <resources/> <connections/> </ui>
ANJ, 21 May 2020 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
