Subject: SoftIOC and Labview
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <[email protected]>
Date: Tue, 26 May 2020 19:16:19 +0000
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
    field(DTYP,"Soft Channel")
    field(NELM, "10")
    field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
Re: SoftIOC and Labview Paul Sichta via Tech-talk
Prev: Re: Unpredictable behaviour with PyEpics Matt Newville via Tech-talk
Next: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Prev: Re: Mirror Control Room Konrad, Martin via Tech-talk
