1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: SoftIOC and Labview
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <tech-talk at aps.anl.gov>
To: Paul Sichta <psichta at pppl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 26 May 2020 19:36:17 +0000
Writing double scalar values to a ai record works great.
I tried both aai and waveform to write array values of doubles but no success.
I am using LabView 2018 SP1. Do you have a list of what's working and what's not?
Best,
Jalal
Sent: Tuesday, May 26, 2020 9:28:39 PM
To: Mostafa, Jalal (IPE)
Cc: tech-talk at aps.anl.gov
Jalal,
Can your labview write scalar values (e.g. to a longin record ) to your softioc?
Have you tried writing your labview array to a waveform record on the softioc?
Using earlier versions of the NI EPICS software, I seem to recall there were some data types that wouldn't work (I think double was OK).  I haven't tried the 2020 version but glad to see it has been updated.
-ps
On Tue, May 26, 2020 at 3:18 PM Mostafa, Jalal (IPE) via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi All!
I am trying to write an array of doubles from a LabView EPICS Client using EPICS Client I/O Server to a softIoc instance with the corresponding record:
record(aai, "dummy:array")
    field(DTYP,"Soft Channel")
    field(NELM, "10")
    field(FTVL, "DOUBLE")
I can see the LabVIEW being connected to this record but no written values to softIoc instance. The issue is only happening on LabView but not when using other clients like caput for instance.
What is the correct way to write array values from LabView to softIoc records?
Best,
Jalal
Re: SoftIOC and Labview Paul Sichta via Tech-talk
SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Prev: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Next: Re: SoftIOC and Labview Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 26 May 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
