On 6/1/20 5:48 PM, Engbretson, Mark S. wrote:
> Can't you keep both revision and date? Knowing that something was compiled 2 years ago means much more to me than a revision number which is meaningless to me unless i actually know what the current release is. Unless this test was performed at run time and told me how far out of sync this was with the master branch.
A revision is useful to me when it shows up
here on tech-talk along with a request for help.
Also, recent GCC complains about use of __DATE__ wrt.
https://reproducible-builds.org/ (which I agree with)
> *From:* Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
> *Sent:* Monday, June 1, 2020 7:40:02 PM
> *To:* Rivers, Mark L. <rivers at cars.uchicago.edu>
> *Cc:* 'tech-talk' <tech-talk at aps.anl.gov>
> *Subject:* Re: Minor issues building base 7.0.4 on Windows
> What you are describing is a result of a change I made
> to include VCS revision in the build in place of __DATE__.
> This makes the output of eg. iocInit a bit more useful.
>> Starting iocInit
>> ## EPICS R7.0.4.1-DEV
>> ## Rev. R7.0.4-36-g4ba9dafeef3934e5e10d
> Or anything which calls coreRelease() from epicsRelease.h
> If no VCS tool is in use (eg. no '.git'), or not available,
> the default fallback is to use the current time with minute precision.
> (cf. src/tools/genVersionHeader.pl)
> https://github.com/epics-base/epics-base/commit/b43aafae701b4b4fd835117cf63b2e563482184b
> https://epics.anl.gov/core-talk/2019/msg01402.php
> On 6/1/20 3:40 PM, Mark Rivers via Tech-talk wrote:
>> Correction:
>> Ø Normally when “make” completes successfully and then one runs “make” again it does not actually do anything. For base 7.0.4 that is what I observe for Linux. But on Windows every time I run “make” after it has completed successfully it produces the following output.
>> Actually on base 7.0.4 it does recompile on Linux as well, you just don’t see any output if using –sj.
>> But this problem does not occur on base 7.0.3.1. Here is the output when I rebuild with windows-x64-static on base 7.0.3.1.
>> H:\epics\base-7.0.3.1>make -sj8
>> It does not do anything, but on 7.0.4 there is lots of output as it recompiles and rebuilds libraries each time you run it.
>> Mark
>> *From:* Mark Rivers
>> *Sent:* Monday, June 1, 2020 3:31 PM
>> *To:* tech-talk <tech-talk at aps.anl.gov>
>> *Subject:* Minor issues building base 7.0.4 on Windows
>> When I try to build base 7.0.4 on windows-x64-static with Visual Studio 2015 I have the following issues, which appear to be minor:
>> 1) “make clean uninstall” produces many error messages like this:
>> H:\epics-devel\base-7.0.4>make -sj clean uninstall
>> Can't locate EPICS/Path.pm in @INC (you may need to install the EPICS::Path module) (@INC contains: H:/epics-devel/base-7.0.4/src/tools/../../lib/perl C:/Perl64/site/lib C:/Perl64/lib .) at H:/epics-devel/base-7.0.4/src/tools/convertRelease.pl line 24.
>> BEGIN failed--compilation aborted at H:/epics-devel/base-7.0.4/src/tools/convertRelease.pl line 24.
>> 2) “make –sj” produces these messages:
>> H:\epics-devel\base-7.0.4>make –sj8 > windows_build1.txt
>> 'git' is not recognized as an internal or external command,
>> operable program or batch file.
>> 3) Normally when “make” completes successfully and then one runs “make” again it does not actually do anything. For base 7.0.4 that is what I observe for Linux. But on Windows every time I run “make” after it has completed successfully it produces the following output.
>> epicsRelease.c
>> Appending rsrvIocRegister.obj
>> Appending online_notify.obj
>> Appending cast_server.obj
>> Appending camessage.obj
>> Appending camsgtask.obj
>> Appending caservertask.obj
>> Appending caserverio.obj
>> Appending registryIocRegister.obj
>> Appending registryCommon.obj
>> Appending registryFunction.obj
>> Appending registryJLinks.obj
>> Appending registryDriverSupport.obj
>> Appending registryDeviceSupport.obj
>> Appending registryRecordType.obj
>> Appending iocshRegisterCommon.obj
>> Appending dlload.obj
>> Appending miscIocRegister.obj
>> Appending iocInit.obj
>> Appending epicsRelease.obj
>> Appending dbtoolsIocRegister.obj
>> Appending dbLoadTemplate.obj
>> Appending dbStaticIocRegister.obj
>> Appending dbStaticRun.obj
>> Appending dbPvdLib.obj
>> Appending dbYacc.obj
>> Appending dbStaticLib.obj
>> Appending dbServer.obj
>> Appending dbUnitTest.obj
>> Appending dbState.obj
>> Appending chfPlugin.obj
>> Appending dbIocRegister.obj
>> Appending dbContextReadNotifyCache.obj
>> Appending dbPutNotifyBlocker.obj
>> Appending dbSubscriptionIO.obj
>> Appending dbChannelIO.obj
>> Appending dbContext.obj
>> Appending cvtBpt.obj
>> Appending dbCaTest.obj
>> Appending dbCa.obj
>> Appending callback.obj
>> Appending recGbl.obj
>> Appending db_test.obj
>> Appending db_access.obj
>> Appending dbTest.obj
>> Appending dbEvent.obj
>> Appending dbScan.obj
>> Appending dbNotify.obj
>> Appending dbLink.obj
>> Appending dbJLink.obj
>> Appending dbExtractArray.obj
>> Appending dbFastLinkConv.obj
>> Appending dbDbLink.obj
>> Appending dbConvertJSON.obj
>> Appending dbConvert.obj
>> Appending dbConstLink.obj
>> Appending dbChannel.obj
>> Appending dbBkpt.obj
>> Appending dbAccess.obj
>> Appending dbLock.obj
>> Appending asIocRegister.obj
>> Appending asCa.obj
>> Appending asDbLib.obj
>> Appending lnkDebug.obj
>> Appending lnkState.obj
>> Appending lnkCalc.obj
>> Appending lnkConst.obj
>> Appending decimate.obj
>> Appending sync.obj
>> Appending arr.obj
>> Appending dbnd.obj
>> Appending ts.obj
>> Appending asSubRecordFunctions.obj
>> Appending devEnviron.obj
>> Appending devStdio.obj
>> Appending devTimestamp.obj
>> Appending devGeneralTime.obj
>> Appending devSoSoftCallback.obj
>> Appending devPrintfSoftCallback.obj
>> Appending devMbboDirectSoftCallback.obj
>> Appending devMbboSoftCallback.obj
>> Appending devLsoSoftCallback.obj
>> Appending devLoSoftCallback.obj
>> Appending devI64outSoftCallback.obj
>> Appending devCalcoutSoftCallback.obj
>> Appending devBoSoftCallback.obj
>> Appending devAoSoftCallback.obj
>> Appending devSiSoftCallback.obj
>> Appending devMbbiSoftCallback.obj
>> Appending devMbbiDirectSoftCallback.obj
>> Appending devLiSoftCallback.obj
>> Appending devI64inSoftCallback.obj
>> Appending devBiSoftCallback.obj
>> Appending devAiSoftCallback.obj
>> Appending devWfSoft.obj
>> Appending devSoSoft.obj
>> Appending devSiSoft.obj
>> Appending devSASoft.obj
>> Appending devPrintfSoft.obj
>> Appending devMbboSoftRaw.obj
>> Appending devMbboSoft.obj
>> Appending devMbboDirectSoftRaw.obj
>> Appending devMbboDirectSoft.obj
>> Appending devMbbiSoftRaw.obj
>> Appending devMbbiSoft.obj
>> Appending devMbbiDirectSoftRaw.obj
>> Appending devMbbiDirectSoft.obj
>> Appending devLsoSoft.obj
>> Appending devLsiSoft.obj
>> Appending devLoSoft.obj
>> Appending devLiSoft.obj
>> Appending devI64outSoft.obj
>> Appending devI64inSoft.obj
>> Appending devHistogramSoft.obj
>> Appending devEventSoft.obj
>> Appending devCalcoutSoft.obj
>> Appending devBoDbState.obj
>> Appending devBoSoftRaw.obj
>> Appending devBoSoft.obj
>> Appending devBiDbState.obj
>> Appending devBiSoftRaw.obj
>> Appending devBiSoft.obj
>> Appending devAoSoftRaw.obj
>> Appending devAoSoft.obj
>> Appending devAiSoftRaw.obj
>> Appending devAiSoft.obj
>> Appending devAaoSoft.obj
>> Appending devAaiSoft.obj
>> Appending waveformRecord.obj
>> Appending subArrayRecord.obj
>> Appending subRecord.obj
>> Appending stringoutRecord.obj
>> Appending stringinRecord.obj
>> Appending stateRecord.obj
>> Appending seqRecord.obj
>> Appending selRecord.obj
>> Appending printfRecord.obj
>> Appending permissiveRecord.obj
>> Appending mbboDirectRecord.obj
>> Appending mbboRecord.obj
>> Appending mbbiDirectRecord.obj
>> Appending mbbiRecord.obj
>> Appending lsoRecord.obj
>> Appending lsiRecord.obj
>> Appending longoutRecord.obj
>> Appending longinRecord.obj
>> Appending int64outRecord.obj
>> Appending int64inRecord.obj
>> Appending histogramRecord.obj
>> Appending fanoutRecord.obj
>> Appending eventRecord.obj
>> Appending dfanoutRecord.obj
>> Appending compressRecord.obj
>> Appending calcoutRecord.obj
>> Appending calcRecord.obj
>> Appending boRecord.obj
>> Appending biRecord.obj
>> Appending aSubRecord.obj
>> Appending aoRecord.obj
>> Appending aiRecord.obj
>> Appending aaoRecord.obj
>> Appending aaiRecord.obj
>> Appending ioRecord.obj
>> Appending arrRecord.obj
>> Appending xRecord.obj
>> Appending jlinkz.obj
>> Appending devx.obj
>> Appending xLink.obj
>> Appending dbLinkdset.obj
>> Appending asTestLib.obj
>> dbHeaderTest.c
>> dbHeaderTestxx.cpp
>> Appending reftrackioc.obj
>> Appending PVAClientRegister.obj
>> Appending PVAServerRegister.obj
>> Appending pvaClientRPC.obj
>> Appending pvaClientNTMultiMonitor.obj
>> Appending pvaClientNTMultiGet.obj
>> Appending pvaClientNTMultiData.obj
>> Appending pvaClientNTMultiPut.obj
>> Appending pvaClientMultiMonitorDouble.obj
>> Appending pvaClientMultiPutDouble.obj
>> Appending pvaClientMultiGetDouble.obj
>> Appending pvaClientMultiChannel.obj
>> Appending pvaClientPutGet.obj
>> Appending pvaClientMonitor.obj
>> Appending pvaClientPut.obj
>> Appending pvaClientGet.obj
>> Appending pvaClientProcess.obj
>> Appending pvaClientChannel.obj
>> Appending pvaClientMonitorData.obj
>> Appending pvaClientGetData.obj
>> Appending pvaClientPutData.obj
>> Appending pvaClientData.obj
>> Appending pvaClient.obj
>> Appending pvalink_channel.obj
>> Appending pvalink_link.obj
>> Appending pvalink_jlif.obj
>> Appending pvalink_lset.obj
>> Appending pvalink.obj
>> Appending tpool.obj
>> Appending dbf_copy.obj
>> Appending configparse.obj
>> Appending pdbgroup.obj
>> Appending imagedemo.obj
>> Appending demo.obj
>> Appending pdbsingle.obj
>> Appending pdb.obj
>> Appending qsrv.obj
>> Appending pvif.obj
>> Appending scalarAlarmSupport.obj
>> Appending controlSupport.obj
>> Appending processRecordRegister.obj
>> Appending addRecordRegister.obj
>> Appending removeRecordRegister.obj
>> Appending traceRecordRegister.obj
>> Appending processRecord.obj
>> Appending addRecord.obj
>> Appending removeRecord.obj
>> Appending traceRecord.obj
>> Appending registerChannelProviderLocal.obj
>> Appending monitorFactory.obj
>> Appending channelLocal.obj
>> Appending channelProviderLocal.obj
>> Appending pvDatabase.obj
>> Appending pvRecord.obj
>> Appending pvTimestampPlugin.obj
>> Appending pvDeadbandPlugin.obj
>> Appending pvArrayPlugin.obj
>> Appending pvCopy.obj
>> Appending pvPlugin.obj
>> So it appears to be recompiling epicsRelease.c, dbHeaderTest.c, and dbHeaderTestxx.cpp and rebuilding the libraries that contain those.
>> Mark
- Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
- RE: Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
- Re: Minor issues building base 7.0.4 on Windows Michael Davidsaver via Tech-talk
- Re: Minor issues building base 7.0.4 on Windows Engbretson, Mark S. via Tech-talk
Re: Minor issues building base 7.0.4 on Windows Mark Rivers via Tech-talk
<2020>
2025
<2020>
2025
