Subject: Re: prosilicaSupport for arm
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Pierrick M Hanlet <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 8 Jun 2020 14:05:44 -0700
On 6/8/20 1:34 PM, Mark Rivers wrote:
> Folks,
>> Using one of the drivers based on the open source aravis library seems a better option for portability.
> Pierrick had taken our conversation off of tech-talk.  I have appended some of the messages we have exchanged on this topic.
I thought this might be the case.  Thanks for bringing the conclusions back on list.
> In this case the vendor does provide their supported Vimba SDK for ARM.  They will presumably provide tech support for any issues.
> On the other hand I am not sure what the state of building ARM support in aravis is.  There are at least 2 issues with cross-compiling for ARM on the aravis git site that do not show successful resolution:
> https://github.com/AravisProject/aravis/issues/245
> https://github.com/AravisProject/aravis/issues/207
> The libaravis-dev packages do appear to be available for Debian arm.  But they only include aravis 0.6, while areaDetector ADAravis and aravisGigE currently require 0.7.2 because that fixes serious caching bugs.
> Mark
> ________________________________
> From: Mark Rivers
> Sent: Thursday, June 4, 2020 10:48 PM
> To: 'Pierrick M Hanlet'
> Subject: RE: prosilicaSupport for arm
> The Vimba SDK you need to download for ARM is on this page:
> https://www.alliedvision.com/en/products/software.html
> This is the download link:
> https://www.alliedvision.com/en/products/software.html#agb-modal-content-5496
> Let me know if you questions or problems.
> Mark
> -----Original Message-----
> From: Pierrick M Hanlet <[email protected]>
> Sent: Thursday, June 4, 2020 9:49 PM
> Thanks again Mark,
> I suspect that now I need to know what is SDK, so that I can download the libVimbaC.so file for arm.
> Would the be found in the link that you gave me a couple of days ago.
> Just in case you've not figured it out already, I know very little about cameras.
> Best wishes,
> Pierrick
> On 6/4/20 8:42 PM, Mark Rivers wrote:
>> Just to be clear the libVimbaC.so files came from me downloading the SDK and extracting those files, adding them to ADVimba. You need to do that for ARM.
>> ADVimba can communicate with your Prosilica camera. I am using that exclusively now, I no longer use ADProsilica.
>> Mark
>> Sent from my iPhone
>>> On Jun 4, 2020, at 8:26 PM, Pierrick M Hanlet <[email protected]> wrote:
>>> Hi Mark,
>>> I'm attempting to follow your advice regarding using ADVimba.
>>> Unfortunately this doesn't build either
>>> since there is no libVimbaC.so.  I'm not certain from where this file
>>> originates, but in vimbaSupportC/os/
>>> there are directories for windows and linux-x86 with the shared object
>>> libraries, but not for arm.
>>> BTW, I'm not certain how vimba is used for the Prosilica camera. It's
>>> build requires ADGenICam.
>>> What I'm really trying to do is to build ADProsilica, or something that
>>> communicates with my
>>> Prosilica GC camera, as a support module.  The IOC will come later.
>>> Thanks again,
>>> Pierrick
>>>> On 6/2/20 6:10 PM, Mark Rivers wrote:
>>>> Hi Pierrick,
>>>> If you go to this link:
>>>> https://urldefense.proofpoint.com/v2/url?u=https-3A__www.alliedvision.com_en_support_software-2Ddownloads.html&d=DwIGaQ&c=gRgGjJ3BkIsb5y6s49QqsA&r=lWgMUJ9IIDH_eCcPLDGLwQ&m=Vpl7b7UwplPdOJbLQ3fvlO3U9Eg3ZCRic1Qz6bsAB80&s=BPK2roq6z1XsgZKVrUOZh_KAsxNuTM9m7kyRkZbFr0I&e=
>>>> and select "Legacy Software" you will see PvAPI.  They claim the Linux PvAPI support includes ARM.
>>>> That said, you might want to switch to ADVimba instead.  It uses the Vimba SDK that AVT actively supports, whereas ADProsilica uses the obsolete PvAPI SDK.
>>>> Mark
>>>> From: Tech-talk <[email protected]> On Behalf Of Pierrick M Hanlet via Tech-talk
>>>> Sent: Tuesday, June 2, 2020 5:46 PM
>>>> To: [email protected]
>>>> Subject: prosilicaSupport for arm
>>>> Hi Mark,
>>>> I'd like to run my Prosilica GigE from a raspberry pi and I find that in ./prosilicaSupport/os there is no linux-arm directory with libPvAPI.a.  The README tells from where you downloaded the software, but all I see there is Vimba, but no libPvAPI.a library, though what I found does have an arm version.
>>>> Any suggestions as to how to move forward?
>>>> Thanks,
>>>> Pierrick
>>>> Pierrick Hanlet
>>>> Fermi National Accelerator
>>>> Accelerator Front End Controls
>>>> +1-630-840-5555 -- lab
>>>> +1-312-687-4980 -- mobile
>>>> "Whether you think you can or think you can't, you're right" -- Henry Ford
>>> Pierrick Hanlet
> Pierrick Hanlet
> From: Tech-talk <[email protected]> on behalf of Michael Davidsaver via Tech-talk <[email protected]>
> Sent: Monday, June 8, 2020 2:53 PM
> To: Pierrick M Hanlet
> Cc: [email protected]
> On 6/2/20 3:45 PM, Pierrick M Hanlet via Tech-talk wrote:
>> Hi Mark,
> for portability.
>> $ sudo apt-get install aravis-tools libaravis-dev
>> $ arv-viewer
prosilicaSupport for arm Pierrick M Hanlet via Tech-talk
Re: prosilicaSupport for arm Michael Davidsaver via Tech-talk
Re: prosilicaSupport for arm Mark Rivers via Tech-talk
Prev: Re: prosilicaSupport for arm Mark Rivers via Tech-talk
Next: weird record names? Michael Davidsaver via Tech-talk
Next: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
