Subject: Update a record at a specific time
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 03 Jun 2020 13:45:32 +0200
Hello,
For archiving purposes I am trying to record a value from a PV everyday at a specific time. I accomplished similar things using a Soft Timestamp record when a specific date/time field updates. ie:
record(stringin, "TeslaMeters:$(position):TimeStamp"){
    field(DTYP, "Soft Timestamp")
    field(PINI, "YES")
    field(INP,  "@%d")
record(calcout, "TeslaMeters:$(position):Calc"){
   field(INPA, "TeslaMeters:$(position):TimeStamp CP")
   field(INPB, "TeslaMeters:$(position)")
   field(CALC, "B")
   field(OUT, "TeslaMeters:$(position):Midnight PP")
record(ai, "TeslaMeters:$(position):Midnight")
    field(PREC, "3")
    field(EGU,  "Tesla")
    field(PINI, "YES")
Could I use a similar strategy to compare a time string generated by the Soft Timestamp? I see that there is a scalcout record, but i was not able to get it to work. Additionally, a simple follow up question that I am not able to solve in a simple way. Is there a simple way to create a "if" statement without the "else" part. As in, I would like the OUT record processed only then the "if" condition is met.
Thank you,
Donny
Donny Domagoj Cosic
 Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Re: Update a record at a specific time Mark Rivers via Tech-talk
Prev: prosilicaSupport for arm Pierrick M Hanlet via Tech-talk
Next: Re: Update a record at a specific time Mark Rivers via Tech-talk
Prev: Re: prosilicaSupport for arm Michael Davidsaver via Tech-talk
