Subject: Re: Update a record at a specific time
To: Donny Domagoj Cosic <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 3 Jun 2020 12:03:47 +0000
 > Additionally, a simple follow up question that I
> am not able to solve in a simple way. Is there a simple way to create a
> "if" statement without the "else" part. As in, I would like the OUT
> record processed only then the "if" condition is met.
I'm not positive I understand the question.  But if you can make your calculation "if" return 0 or non-zero then the calcout record has an OOPT field that can be either "Transition To Zero" or "Transition To Non-zero" (among other choices).  That will write the output only under the specified condition.  It also has a DOPT field that lets you write a different value from the result of the calculation if you set it to "Use OCAL" rather than "Use CAL".
From: Tech-talk <[email protected]> on behalf of Donny Domagoj Cosic via Tech-talk <[email protected]>
Sent: Wednesday, June 3, 2020 6:45 AM
To: [email protected]
Subject: Update a record at a specific time
Hello,
For archiving purposes I am trying to record a value from a PV everyday
at a specific time. I accomplished similar things using a Soft Timestamp
record when a specific date/time field updates. ie:
record(stringin, "TeslaMeters:$(position):TimeStamp"){
     field(DTYP, "Soft Timestamp")
     field(PINI, "YES")
     field(INP,  "@%d")
record(calcout, "TeslaMeters:$(position):Calc"){
    field(INPA, "TeslaMeters:$(position):TimeStamp CP")
    field(INPB, "TeslaMeters:$(position)")
    field(CALC, "B")
    field(OUT, "TeslaMeters:$(position):Midnight PP")
record(ai, "TeslaMeters:$(position):Midnight")
     field(PREC, "3")
     field(EGU,  "Tesla")
     field(PINI, "YES")
Could I use a similar strategy to compare a time string generated by the
Soft Timestamp? I see that there is a scalcout record, but i was not
able to get it to work. Additionally, a simple follow up question that I
Thank you,
Donny
Donny Domagoj Cosic
  Institut Ruder Boskovic, Bijenicka cesta 54, 10000 Zagreb, Croatia
Re: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
Prev: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
Next: Lexium MDrive Ethernet Stubbs Scott Allen (PSI) via Tech-talk
Next: Re: Update a record at a specific time Donny Domagoj Cosic via Tech-talk
