Subject: Re: Update a record at a specific time
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 03 Jun 2020 15:32:41 +0200
Hi Mark,
Thank you for your response,
I was referring to the CALC field of the calcout record:
record(calcout, "Name"){
   field(INPA, "In_A")
   field(INPB, "In_B")
   field(CALC, "A==10?B")
   field(OUT, "Out")
the line "field(CALC, "A==10?B")" is not valid because there is no else statement ie. "A==10?B:0". If i understood your response correctly, this can be accomplished by setting the OOPT field to "Transition To Non-zero" and the record will only write the output when it is non zero.
Donny
Donny Domagoj Cosic
 Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Dana 03.06.2020 14:03, Mark Rivers via Tech-talk je napisao(la):
Additionally, a simple follow up question that I
am not able to solve in a simple way. Is there a simple way to create a
"if" statement without the "else" part. As in, I would like the OUT
record processed only then the "if" condition is met.
I'm not positive I understand the question.  But if you can make your
calculation "if" return 0 or non-zero then the calcout record has an
OOPT field that can be either "Transition To Zero" or "Transition To
Non-zero" (among other choices).  That will write the output only
under the specified condition.  It also has a DOPT field that lets you
write a different value from the result of the calculation if you set
it to "Use OCAL" rather than "Use CAL".
From: Tech-talk <[email protected]> on behalf of Donny
Sent: Wednesday, June 3, 2020 6:45 AM
Subject: Update a record at a specific time
Hello,
For archiving purposes I am trying to record a value from a PV everyday
at a specific time. I accomplished similar things using a Soft Timestamp
record when a specific date/time field updates. ie:
record(stringin, "TeslaMeters:$(position):TimeStamp"){
     field(DTYP, "Soft Timestamp")
     field(PINI, "YES")
     field(INP,  "@%d")
record(calcout, "TeslaMeters:$(position):Calc"){
    field(INPA, "TeslaMeters:$(position):TimeStamp CP")
    field(INPB, "TeslaMeters:$(position)")
    field(CALC, "B")
    field(OUT, "TeslaMeters:$(position):Midnight PP")
record(ai, "TeslaMeters:$(position):Midnight")
     field(PREC, "3")
     field(EGU,  "Tesla")
     field(PINI, "YES")
Could I use a similar strategy to compare a time string generated by the
Soft Timestamp? I see that there is a scalcout record, but i was not
able to get it to work. Additionally, a simple follow up question that I
Thank you,
Donny
Donny Domagoj Cosic
  Institut Ruder Boskovic, Bijenicka cesta 54, 10000 Zagreb, Croatia
Re: Update a record at a specific time Mark Rivers via Tech-talk
Update a record at a specific time Donny Domagoj Cosic via Tech-talk
Prev: Lexium MDrive Ethernet Stubbs Scott Allen (PSI) via Tech-talk
Next: Re: Update a record at a specific time Mark Rivers via Tech-talk
Prev: Re: Update a record at a specific time Mark Rivers via Tech-talk
