1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: EPICS_BASE smart definition
From: "Konrad, Martin via Tech-talk" <tech-talk at aps.anl.gov>
To: Touchard Dominique <dominique.touchard at ganil.fr>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 9 Jun 2020 18:09:29 +0000
Hi Dominique,
> On our site we used to have only one EPICS base with supports linked on.
> The goal is to install few EPICS releases on site with a smart approach.
> The goal is at the end, to containerise(?) each application.
Sounds like you want to pick one of these two approaches. If you
containerize your IOCs each container only needs to contain one version
of EPICS Base. If you want to upgrade, you stop the old container and
start a fresh one built with the new version of EPICS Base. (Keep the
old one around for a while in case you need to roll back.)
> EPICS_BASE:=$(shell echo ${EPICS_BASE})
A potential problem with this is that you might be modifying a file
which is under revision control. It's easy git revert this change by
accident. Ralph's CI scripts generate a RELEASE.local file which only
contains autogenerated stuff and doesn't even need to be in the checked
out source directory (it can live one level above). He simply includes
it by appending
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
to the end of the existing static RELEASE file. More and more modules
already come with these lines [1,2].
Hope that helps,
Martin
[1]
https://github.com/epics-modules/asyn/blob/master/configure/RELEASE#L19-L21
[2]
https://github.com/epics-modules/motor/blob/master/configure/RELEASE#L47-L49
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: konrad at frib.msu.edu
Prev: EPICS_BASE smart definition Touchard Dominique via Tech-talk
Next: Re: EPICS_BASE smart definition Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: EPICS_BASE smart definition Ralph Lange via Tech-talk
Next: Re: RE: iocLogServer, logstash & procServ 吴煊 via Tech-talk
ANJ, 09 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
