Subject: How to run IOC in docker containers properly
To: [email protected]
Date: Mon, 15 Jun 2020 15:23:01 +0800
Hi all,
The only way of starting an IOC I have learned is by running the `st.cmd` script, which by default opens an iocsh shell on success. I am seeing 2 problems when running IOCs in containers:
1. The iocsh shell seems redundant as nobody will actually use it when run in containers. A way to start IOC which does not open up iocsh is a more light-weight solution.
2. When running an IOC container with `-d` option only, the container stops immediately. A dirty workaround is using `-it` option to attach a pseudo-tty to the container. The caveat is that when the IOC is broken the container keeps running. Although a liveliness probe can be used to check the health condition of the IOC, a container exiting when the IOC is broken is certainly a more light-weight and reliable solution.
TL;DR, is there a proper way to start a persistent iocsh-less IOC instance?
Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Prev: Re: weird record names? Michael Davidsaver via Tech-talk
Next: Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
Prev: Keysight support Roehrig, Christian via Tech-talk
