Subject: Re: How to run IOC in docker containers properly
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 15 Jun 2020 09:32:50 +0200
Hey Xiao,
we are using Docker containers for our IOCs as well. We start the container with the "-dit" options. The additional "-it" creates an interactive TTY which keeps the iocsh alive within the container. Also with this option you can "enter" the container and work with the iocsh by using the command:
`docker attach <container id>`
Leave the iocsh with `CTRL+p CTRL+q`
HTH Florian
Am 15.06.2020 um 09:23 schrieb xiao zhang via Tech-talk:
Hi all,
The only way of starting an IOC I have learned is by running the `st.cmd` script, which by default opens an iocsh shell on success. I am seeing 2 problems when running IOCs in containers:
1. The iocsh shell seems redundant as nobody will actually use it when run in containers. A way to start IOC which does not open up iocsh is a more light-weight solution. 2. When running an IOC container with `-d` option only, the container stops immediately. A dirty workaround is using `-it` option to attach a pseudo-tty to the container. The caveat is that when the IOC is broken the container keeps running. Although a liveliness probe can be used to check the health condition of the IOC, a container exiting when the IOC is broken is certainly a more light-weight and reliable solution.
TL;DR, is there a proper way to start a persistent iocsh-less IOC instance?
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
How to run IOC in docker containers properly xiao zhang via Tech-talk
Prev: How to run IOC in docker containers properly xiao zhang via Tech-talk
Next: Re: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
Next: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
