1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Re: How to run IOC in docker containers properly
From: xiao zhang via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 15 Jun 2020 16:03:02 +0800
Hi Florian
Thanks for sharing your experience. But I am not satisfied with the way it has to be.
As mentioned in my original post, the current method has 2 caveats:
1. Unnecessary overhead as entering the interactive shell of a running container is not part of a normal workflow
2. The container does not exit when the IOC process breaks
An iocsh-less way to start IOC solves both the above concerns as only `-d` option is required in this case. When the IOC process breaks, the container will exit immediately and tell the outer world that it is broken, so that a restart can be scheduled either manually or by an automatic container orchestrator.
Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
Prev: Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
Next: Re: How to run IOC in docker containers properly Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: Notifying systemd when IOC start is complete (plus showing progress) Ben Franksen via Tech-talk
ANJ, 24 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
