Subject: Re: Notifying systemd when IOC start is complete (plus showing progress)
From: Ben Franksen via Tech-talk <[email protected]>
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 24 Jun 2020 18:01:08 +0200
Am 23.06.20 um 00:46 schrieb Konrad, Martin via Tech-talk:
>> And how do you signal readiness to systemd? Make the IOC core depend
>> on the sd-notify API?
> I first thought about that but that would obviously require modifying
> EPICS Base or writing a extension (which sounds like overkill for
> essentially one line of code). But looking at the systemd documentation
> I realized that there is actually a simpler way that I wasn't aware of
> so far: Adding the following line at the end of st.cmd does the trick:
> system '/usr/bin/systemd-notify --ready'
> systemd-notify simply wraps sd-notify. This of course requires
> Type=notify
> NotifyAccess=all
> in the foo.service file.
Ah, nice. I had forgotten about the wrapper tool.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Re: How to run IOC in docker containers properly Konrad, Martin via Tech-talk
Notifying systemd when IOC start is complete (plus showing progress) Konrad, Martin via Tech-talk
Prev: Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Next: Re: [EXTERNAL] Re: How to run IOC in docker containers properly Michael Davidsaver via Tech-talk
Prev: Notifying systemd when IOC start is complete (plus showing progress) Konrad, Martin via Tech-talk
Next: Re: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
