Subject: Re: How to run IOC in docker containers properly
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 17 Jun 2020 15:55:09 +0000
On Jun 17, 2020, at 9:20 AM, J. Lewis Muir via Tech-talk <[email protected]> wrote:
On 06/17, Ben Franksen via Tech-talk wrote:
The standard method run run IOCs on a linux machine is to use provServ.
Or, depending on the requirements, IOCs can be run inside tmux.  This is
what I do.
Or GNU Screen similarly. I’m considering using a combination of GNU Screen (for multi-user access to the console, logging and screen history buffer recall) to run procServ -f (for IOC start/stop/restart) that runs a script which exec’s the IOC binary, although I haven’t actually tried that full combination yet.
IOCs in a control system generally perform a different role than many containerized applications such as web-servers since they aren’t usually started and stopped based on user demand and there aren’t many instances running exactly the same code and configuration. Don’t assume that all of the features of standard containers are useful for running EPICS IOCs.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
How to run IOC in docker containers properly xiao zhang via Tech-talk
Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Re: How to run IOC in docker containers properly Ben Franksen via Tech-talk
Prev: RE: Re: No PV record found when build ASYN application on Windows Mark Rivers via Tech-talk
Next: Re: tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Prev: Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
Next: Re: How to run IOC in docker containers properly J. Lewis Muir via Tech-talk
