> Should I run the bat file in Windows command prompt or MingGW?
You should run it in whatever shell you will then run the IOC.
> $ ../../bin/windows-x64-mingw/exampleAsyn.exe st.cmd
> Invalid directory path, ignored
> filename="../dbStatic/dbLexRoutines.c" line number=264
Please send the complete output when you run that command.
No such file or directory dbRead opening file /home/ihep/support/asyn/4-39/db/asynRecord.db
You are running on Windows, but that file path is using Linux syntax, not Windows. What shell are you running when you execute the command to run the IOC?
Can you send the envPaths file that was generated in the /iocBoot/iocexampleAsyn directory.
Sent: Wednesday, June 17, 2020 5:22 AM
Subject: No PV record found when build ASYN application on Windows
I met two problems when I tried to include asynRecord.db in a windows-x64-mingw EPICS example application. The EPICS base is 7.0.3.1 and asyn is 4-39.
I have specified the EPICS_BASE and ASYN paths in the configure/RELEASE file. And I have added exampleAsyn_LIBS += asyn, exampleAsyn_DBD+=asyn.dbd and exampleAsyn_DBD+=drvAsynIPPort.dbd
into src/Makefile. No error was printed while 'make clean install'. However,
C:/msys64/home/ihep/support/asyn/exampleAsyn/bin/windows-x64-mingw/exampleAsyn.exe: error while loading shared libraries: exampleAsynSupport.dll: cannot
open shared object file: No such file or directory
2) Though the IOC was started, there was no pv record.
No such file or directory dbRead opening file dbd/exampleAsyn.dbd
registerRecordDeviceDriver failed aSub
registerRecordDeviceDriver failed aai
registerRecordDeviceDriver failed aao
registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed ao
registerRecordDeviceDriver failed asyn
registerRecordDeviceDriver failed bi
registerRecordDeviceDriver failed bo
registerRecordDeviceDriver failed calc
registerRecordDeviceDriver failed calcout
registerRecordDeviceDriver failed compress
registerRecordDeviceDriver failed dfanout
registerRecordDeviceDriver failed event
registerRecordDeviceDriver failed fanout
registerRecordDeviceDriver failed histogram
registerRecordDeviceDriver failed int64in
registerRecordDeviceDriver failed int64out
registerRecordDeviceDriver failed longin
registerRecordDeviceDriver failed longout
registerRecordDeviceDriver failed lsi
registerRecordDeviceDriver failed lso
registerRecordDeviceDriver failed mbbi
registerRecordDeviceDriver failed mbbiDirect
registerRecordDeviceDriver failed mbbo
registerRecordDeviceDriver failed mbboDirect
registerRecordDeviceDriver failed permissive
registerRecordDeviceDriver failed printf
registerRecordDeviceDriver failed sel
registerRecordDeviceDriver failed seq
registerRecordDeviceDriver failed state
registerRecordDeviceDriver failed stringin
registerRecordDeviceDriver failed stringout
registerRecordDeviceDriver failed sub
registerRecordDeviceDriver failed subArray
registerRecordDeviceDriver failed waveform
registerRecordDeviceDriver failed xxx
registryJLinkAdd failed calc
registryJLinkAdd failed const
registryJLinkAdd failed debug
registryJLinkAdd failed state
registryJLinkAdd failed trace
registryJLinkAdd failed pva
dbLoadTemplate: error opening sub file db/user.substitutions
No such file or directory dbRead opening file db/exampleAsynVersion.db
No such file or directory dbRead opening file db/dbSubExample.db
checkDatabase: menuConvert not defined.
iocBuild: Aborting, bad database definition (DBD)!
#!../../bin/windows-x64-mingw/exampleAsyn
epicsEnvSet("IOC","iocexampleAsyn")
epicsEnvSet("TOP","/home/ihep/support/asyn/exampleAsyn")
epicsEnvSet("ASYN","/home/ihep/support/asyn/4-39")
epicsEnvSet("EPICS_BASE","/home/ihep/base-7.0.3.1")
cd "/home/ihep/support/asyn/exampleAsyn"
dbLoadDatabase "dbd/exampleAsyn.dbd"
exampleAsyn_registerRecordDeviceDriver pdbbase
drvAsynIPPortConfigure("L0","192.168.188.32:4001",0,0,0)
dbLoadRecords("/home/ihep/support/asyn/4-39/db/asynRecord.db","P=guest:,R=asyn,PORT=L0,ADDR=24,IMAX=100,OMAX=100")
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/exampleAsynVersion.db", "user=ihep"
dbLoadRecords "db/dbSubExample.db", "user=ihep"
cd "/home/ihep/support/asyn/exampleAsyn/iocBoot/iocexampleAsyn"
## Start any sequence programs
#seq sncExample, "user=ihep"
I could find exampleAsyn.dbd in dbd/ directory.
I built a same example application on Linux(base 3.15.6, asyn 4-33), and it succeeded. Could someone please help me with this? Thanks a lot.
