Subject: Re: tsub record: assert(prt->no_fields == 558) fails
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: John Dobbins <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Jun 2020 16:16:15 +0000
Hi John,
On Jun 16, 2020, at 11:03 AM, John Dobbins via Tech-talk <[email protected]> wrote:
I am trying to add the tsub record from TPMAC to an IOC.
Everything builds without trouble but when I run the IOC I get an assert failure for number of fields in the tsub record, see console output below.
This is linux-x86_64, using base 7.0.3, asyn-R4-38, motor-R7-1
Are you sure? That Base version isn't what the release message at the end of your email says, and that difference would explain the error:
EPICS Release EPICS R7.0.2.
Local time is 2020-06-16 11:47:22.592146284 EDT
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Prev: tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Next: IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Next: Re: tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
