Subject: tsub record: assert(prt->no_fields == 558) fails
From: John Dobbins via Tech-talk <[email protected]>
Date: Tue, 16 Jun 2020 16:03:34 +0000
All,
I am trying to add the tsub record from TPMAC to an IOC.
Everything builds without trouble but when I run the IOC I get an assert failure for number of fields in the tsub record, see console output below.
This is linux-x86_64, using base 7.0.3, asyn-R4-38, motor-R7-1
Downloaded tpmac-master from
BTW, I did poke around enough to realize I didn't know if 'prt->no_fields' is supposed to be the number of fields or the index of the last field. If I count the tsub record fields in my jbiTest.dbd I get 559.
Hoping you can help me figure out where I went astray.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
www.chess.cornell.edu
jad22@lnx615 $ ../../bin/linux-x86_64/jbiTest st.cmd
#!../../bin/linux-x86_64/jbiTest
< envPaths
epicsEnvSet("IOC","iocjbiTest")
epicsEnvSet("TOP","/nfs/chess/user/jad22/JBluIce/epics/jbiTest")
epicsEnvSet("TPMAC","/nfs/chess/user/jad22/epics/support/tpmac")
epicsEnvSet("EPICS_BASE","/nfs/chess/epics/release/base/base-7.0.2")
dbLoadDatabase("../../dbd/jbiTest.dbd",0,0)
jbiTest_registerRecordDeviceDriver(pdbbase)
A call to 'assert(prt->no_fields == 558)'
    by thread '_main_' failed in ../O.Common/tsubRecord.h line 1145.
Dumping a stack trace of thread '_main_':
[          0x51447b]: ../../bin/linux-x86_64/jbiTest(epicsStackTrace+0x4b)
[          0x50ff8a]: ../../bin/linux-x86_64/jbiTest(epicsAssert+0x3a)
[          0x439c0b]: ../../bin/linux-x86_64/jbiTest(tsubRecordSizeOffset+0x3b)
[          0x4bcae8]: ../../bin/linux-x86_64/jbiTest(registerRecordTypes+0xc8)
[          0x439880]: ../../bin/linux-x86_64/jbiTest(jbiTest_registerRecordDeviceDriver+0x60)
[          0x5026b5]: ../../bin/linux-x86_64/jbiTest(iocshBody+0xb15)
[          0x439552]: ../../bin/linux-x86_64/jbiTest(main+0x12)
[    0x7f0bc7507545]: /lib64/libc.so.6(__libc_start_main+0xf5)
[          0x439752]: ../../bin/linux-x86_64/jbiTest(_start+0x29)
EPICS Release EPICS R7.0.2.
Local time is 2020-06-16 11:47:22.592146284 EDT
Please E-mail this message to the author or to [email protected]
Re: tsub record: assert(prt->no_fields == 558) fails Johnson, Andrew N. via Tech-talk
Re: tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Prev: Re: Lexium MDrive Ethernet Dr. Bastian Löher via Tech-talk
Next: Re: tsub record: assert(prt->no_fields == 558) fails Johnson, Andrew N. via Tech-talk
Prev: Re: ci-scripts 3.0 release: Windows on Travis Torsten Bögershausen via Tech-talk
