Subject: Re: Lexium MDrive Ethernet
From: Dr. Bastian Löher via Tech-talk <[email protected]>
To: "Stubbs Scott Allen (PSI)" <[email protected]>
Date: Tue, 16 Jun 2020 16:59:29 +0200
Dear Scott,
I've (semi-successfully) used the Lexium MDrive with Ethernet, but I've
built my own modbus driver for it. The motorIms did work for very basic
things, but did not support the switches, as you mention.
The modbus driver also does not support the manufacturer specific
functions needed for the I/O setup, so I've had a Python-modbus script
do this at IOC startup.
This was working for us for the current situation (probably a one-off
deal, since other motors are much better integrated with our setup), but
it certainly can be improved upon for more permanent installations.
If you are interested, I'm happy to share the code or else contribute to
development in other drivers.
All the best
Bastian
On 200603-1415, Stubbs Scott Allen (PSI) via Tech-talk wrote:
>    Hi all,
>    I am wondering if anybody has experience with the Lexium MDrive
>    Ethernet
>    motors: [1]https://motion.schneider-electric.com/all-products/mdrive-in
>    telligent-motors/lexium-mdrive/
>    Specifically of interest to us would be integrating
>    TCP/IP closed-loop models LMDCE57x via the EPICS motorIms driver.  From
>    a brief e-mail exchange Lexium MCode appears quite similar for our
>    purposes but there are a few differences, i.e. inputs and outputs are
>    now fixed in hardware so you cannot use S(1,2,3,4) to configure a limit
>    switch input, you would need to assign IS=(1,2,3,4),x,x instead.
>    Thanks & stay healthy,
>    Scott
>    __________________________________________
>    Scott Stubbs
>    Controls Group - SwissFEL
>    Paul Scherrer Institut
>    5232 Villigen PSI
>    Schweiz
>    Telefon: +41 56 310 21 65
>    E-Mail: [email protected]
> Verweise
>    Sichtbare Links:
>    1. https://motion.schneider-electric.com/all-products/mdrive-intelligent-motors/lexium-mdrive/
>    Versteckte Links:
>    3. https://motion.schneider-electric.com/?wpv-control-types%5B%5D=ethernet-tcpip&wpv-feedback-loop%5B%5D=closed&wpv_view_count=7969
Dr. Bastian Löher
Data acquisition
Experiment controls
Detector development
R3B - Relativistic reactions with radioactive beams
Gamma spectroscopy
-- GSI ------------------------------------------------------------------------
Room / Raum: SB3 3.198 (R3B), SB3 4.162 (Gamma spectroscopy)
Phone / Telefon: +49 6159 71 3272 (Office), 1317 (Messhütte), 2934 (Cave C)
Fax: +49 6159 71 2902
Mobile / Mobil: +49 162 5467038
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1, 64291 Darmstadt, Germany, www.gsi.de
Commercial Register / Handelsregister: Amtsgericht Darmstadt, HRB 1528
Managing Directors / Geschäftsführung:
Professor Dr. Paolo Giubellino, Jörg Blaurock
Chairman of the GSI Supervisory Board / Vorsitzender des GSI-Aufsichtsrats:
Ministerialdirigent Dr. Volkmar Dietz
-- TU Darmstadt ---------------------------------------------------------------
Room / Raum: S2|14 418
Phone / Telefon: +49 6151 23532
Institut für Kernphysik
Technische Universität Darmstadt
Schlossgartenstrasse 9, 64289 Darmstadt
http://www.ikp.tu-darmstadt.de
Lexium MDrive Ethernet Stubbs Scott Allen (PSI) via Tech-talk
Prev: Re: How to run IOC in docker containers properly xiao zhang via Tech-talk
Next: tsub record: assert(prt->no_fields == 558) fails John Dobbins via Tech-talk
Prev: Lexium MDrive Ethernet Stubbs Scott Allen (PSI) via Tech-talk
Next: PILZ modbus communications dropouts Brown, Garth via Tech-talk
