Subject: Re: EPICS Records at Runtime
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
Date: Wed, 17 Jun 2020 16:40:52 +0000
Jalal:
What is your use case where records can change very often so that you
wish to load a new database record file after iocInit?  I do not believe
it is possible to change the list of PVs after iocInit.
Changes in the unit of measurement are possible without changes in the
database (by writing to the .EGU field).
Pete
On 6/17/2020 11:31 AM, Bruno Martins via Tech-talk wrote:
> Hi Jalal,
> I believe you are free to register code that runs before iocInit that
> calls dbLoadRecords (see IOC hooks registration [1]).
> I don't know if that can be done after iocInit, probably not?
> [1]
> https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/IOCInitialization.html#x8-2950007.7
> Bruno
> On Wed, Jun 17, 2020 at 12:27 PM Mostafa, Jalal (IPE) via Tech-talk
> <[email protected] <mailto:[email protected]>> wrote:
>     Hi all!
>     We have quite "dynamic" configuration files for EPICS i.e. records
>     can change very often (new records, change in the unit of
>     measurement, ...).
>     Is there a way to load a new database record file after
>     `/iocInit/` without restarting the IOC? or even adding records at
>     runtime?
>     Best,
>     Jalal
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
EPICS Records at Runtime Mostafa, Jalal (IPE) via Tech-talk
Re: EPICS Records at Runtime Bruno Martins via Tech-talk
Prev: Re: EPICS Records at Runtime Bruno Martins via Tech-talk
Next: Re: IOC Startup - init value used sometimes instead of put Paul Nord via Tech-talk
Next: Re: EPICS Records at Runtime Johnson, Andrew N. via Tech-talk
