1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: EPICS Records at Runtime
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: "Mostafa, Jalal (IPE)" <jalal.mostafa at kit.edu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 17 Jun 2020 17:13:24 +0000
On Jun 17, 2020, at 11:25 AM, Mostafa, Jalal (IPE) via Tech-talk <tech-talk at aps.anl.gov> wrote:
We have quite "dynamic" configuration files for EPICS i.e. records can change very often (new records, change in the unit of measurement, ...).
Is there a way to load a new database record file after `iocInit` without restarting the IOC? or even adding records at runtime?
No, sorry. You can change unit strings and scaling at runtime, just modify the EGU and EGUL/EGUF or ESLO/EOFF fields of the records, but adding records after iocInit is not possible at the moment.
The internal IOC data structures that hold the records are not protected by mutexes, so any changes to add new records run the risk of crashing the IOC (people have done that in the past but it was risky). There is no API at all for removing records, and in recent versions of Base dbLoadRecords() will abort if you try to use it after iocInit.
It should obviously be possible to work out what would need to be done to allow that, but it would take some effort to do and the result could slow down some of the internal IOC facilities. In particular record processing and name searches can currently happen at any time, run in other tasks, and the code would need to ensure that those operations don’t try to access the data structures while a new record is getting inserted. There would also probably need to be other changes to support record loading, the parser might need some changes.
If you have resources available (either money or experienced developers) this could be done, but I don’t think it will happen unless & until some lab decides to fund that.
- Andrew
Complexity comes for free, simplicity you have to work for.
EPICS Records at Runtime Mostafa, Jalal (IPE) via Tech-talk
Prev: RE: IOC Startup - init value used sometimes instead of put Mark Rivers via Tech-talk
Next: Re: EPICS Records at Runtime James Larsson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: EPICS Records at Runtime Jemian, Pete R. via Tech-talk
ANJ, 17 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
