Subject: Re: EPICS R3.15.8 and asubRecord issue.
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Mike Westfall <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 18 Jun 2020 18:20:10 +0000
Hi Mike,
On Jun 18, 2020, at 1:00 PM, Mike Westfall via Tech-talk <[email protected]> wrote:
I was trying to compile a simple IOC with an aSub record under EPICS R3.15.8, and I got this error on startup:
dbLoadDatabase("dbd/asub-ioc.dbd")
asub_ioc_registerRecordDeviceDriver(pdbbase)
A call to 'assert(prt->no_fields == 308)'
    by thread '_main_' failed in ../O.Common/aSubRecord.h line 663.
Dumping a stack trace of thread '_main_':
This error was not noted when compiling the same IOC under EPICS R3.14.12.8
I wonder what's going on...
The error means that when your asubRecord.o file was compiled the asubRecord.h file it was built from was created with a different asubRecord.dbd or dbCommon.dbd file than the one the IOC has just loaded. This may mean you didn’t do a ‘make distclean’ when changing Base versions in your RELEASE file, you’re linking with the wrong version of libdbRecStd, or the IOC is loading the wrong .dbd file.
I will look at changing the error message to make it clearer that this is an IOC build problem.
- Andrew
Complexity comes for free, simplicity you have to work for.
EPICS R3.15.8 and asubRecord issue. Mike Westfall via Tech-talk
Prev: EPICS R3.15.8 and asubRecord issue. Mike Westfall via Tech-talk
Next: Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: new version for CA Lab (EPICS <-> LabVIEW interface) 1.7.0.1 Carsten Winkler via Tech-talk
