Subject: Re: Serious problem with base 7.0.4 on Windows
From: Torsten Bögershausen via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, 'tech-talk' <[email protected]>
Date: Sat, 20 Jun 2020 09:03:37 +0200
Could it be, that this commit removed the functionality that we need for Windows ?
commit db6e7c7a22b73f70a8b93e2aa4b6fa505e0218a6
Author: Michael Davidsaver <[email protected]>
Date:   Wed Feb 5 10:30:58 2020 -0800
    use one osdSockAddrReuse impl for all targets
        drop win32 specialization of osdSockAddrReuse
After reading
<https://docs.microsoft.com/en-us/windows/win32/winsock/using-so-reuseaddr-and-so-exclusiveaddruse>
it seems clear that there a different understandings what
SO_REUSEADDR should do, compared UNIX - Windows.
Does `git revert db6e7c7a22b73f70a8b93e2` help ?
On 19/06/20 22:40, Mark Rivers via Tech-talk wrote:
Folks,
I just want to give a heads-up that I have found a serious problem in base 7.0.4 on Windows.  Running a single IOC on a computer works fine. However, additional IOCs started on the same machine cannot be reached with Channel Access.
I assume there will be a patch release soon.  Meanwhile this patch (actually a new file) will fix the problem.
corvette:local/epics/base-7.0.4>git diff R7.0.4 modules/libcom/
diff --git a/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp b/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp
new file mode 100644
index 0000000..cc13605
--- /dev/null
+++ b/modules/libcom/src/osi/os/WIN32/osdSockAddrReuse.cpp
@@ -0,0 +1,44 @@
+* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2002 The Regents of the University of California, as
+*     Operator of Los Alamos National Laboratory.
+* EPICS BASE Versions 3.13.7
+* and higher are distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ * Author: Jeff Hill
+#define epicsExportSharedSymbols
+#include "osiSock.h"
+#include "errlog.h"
+ * Note: WINSOCK appears to assign a different functionality for
+ * SO_REUSEADDR compared to other OS. With WINSOCK SO_REUSEADDR indicates
+ * that simultaneously servers can bind to the same TCP port on the same host!
+ * Also, servers are always enabled to reuse a port immediately after
+ * they exit ( even if SO_REUSEADDR isnt set ).
+LIBCOM_API void epicsStdCall
+    epicsSocketEnableAddressReuseDuringTimeWaitState ( SOCKET s )
+    epicsSocketEnableAddressUseForDatagramFanout ( SOCKET s )
+    int yes = true;
+    int status;
+    status = setsockopt ( s, SOL_SOCKET, SO_REUSEADDR,
+        (char *) & yes, sizeof ( yes ) );
+    if ( status < 0 ) {
+        errlogPrintf (
+            "epicsSocketEnablePortUseForDatagramFanout: "
+            "unable to set SO_REUSEADDR?\n");
Re: Serious problem with base 7.0.4 on Windows Mark Rivers via Tech-talk
Prev: Serious problem with base 7.0.4 on Windows Mark Rivers via Tech-talk
Next: Re: Serious problem with base 7.0.4 on Windows Mark Rivers via Tech-talk
