1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Windows build problem
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 'Freddie Akeroyd - UKRI STFC' <freddie.akeroyd at stfc.ac.uk>, "'Heesterman, Peter J'" <Peter.Heesterman at ukaea.uk>
Cc: 'tech-talk' <tech-talk at aps.anl.gov>
Date: Thu, 25 Jun 2020 22:47:19 +0000
Hi Freddie and Peter,
I am having a Windows build problem I hope you can help me with.
I am working on the TomoPy project which involves tomography reconstruction in Python.  Recently I built tomopy from source, which required me to update my Visual Studio 2017 Community installation because it wanted this version of the runtime.
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.16.27023
That worked fine, and I was able to build TomoPy with Visual Studio 2017.
However, now I am having problems with Visual Studio 2015 on the same machine. I can build EPICS base fine.  However, when I try to build a program of my own that uses the EPICS build system but not EPICS functions in this file I get the following error:
cl -EHsc -GR                -nologo -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE   -Ox -GL -Oy-   -W3 -w44355 -w44344        -MT -DEPICS_BUILD_DLL -TP  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/msvc -I../../../include/os/WIN32 -I../../../include -IH:/epics/base-3.15.5/include/compiler/msvc -IH:/epics/base-3.15.5/include/os/WIN32 -IH:/epics/base-3.15.5/include        -c ../grid.cpp
grid.cpp
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2143: syntax error: missing ')' before 'constant'
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2143: syntax error: missing ';' before 'constant'
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2059: syntax error: 'constant'
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2059: syntax error: ')'
c:\program files (x86)\windows kits\10\include\10.0.17763.0\um\msxml.h(1506): error C2238: unexpected token(s) preceding ';'
../grid.cpp(120): warning C4244: '=': conversion from 'float' to 'long', possible loss of data
The code that is being compiled when it fails is this:
#ifdef _WIN32
  #include <windows.h>
  static LARGE_INTEGER countsPerSecond;
  static double getCurrentTime() {
    LARGE_INTEGER count;
    if (countsPerSecond.QuadPart == 0) QueryPerformanceFrequency(&countsPerSecond);
    QueryPerformanceCounter(&count);
    return double(count.QuadPart)/countsPerSecond.QuadPart;
It is the include <windows.h> that is causing the problem.  If I remove it I get different problems because Windows functions are undefined.
The directory with the file causing the problems is c:\program files (x86)\windows kits\10\include\10.0.17763.0.  That dates from June 22, 2020, which is when I updated Visual Studio 2017.
Any idea how I can fix this?
Re: Windows build problem Michael Davidsaver via Tech-talk
RE: Windows build problem Heesterman, Peter J via Tech-talk
Prev: Re: [EXTERNAL] Re: How to run IOC in docker containers properly Johnson, Andrew N. via Tech-talk
Next: Re: Windows build problem Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: GTEST: Google Test with full EPICS support, as a module Ralph Lange via Tech-talk
ANJ, 26 Jun 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
