Subject: Re: Sub record not finding INAM and SNAM
From: Ernesto Paiser via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Mon, 29 Jun 2020 16:02:45 -0700
Hi Michael/Andrew,
Here is the record:
# conditioning record
record(sub,"$(device):CndtnSB") {
           field(DESC, "")
           field(SCAN, "Passive")
           field(PINI, "NO")
           field(PHAS, "0")
           field(EVNT, "0")
           field(DISV, "1")
           field(SDIS, "0")
           field(DISS, "NO_ALARM")
           field(PRIO, "MEDIUM")
           field(FLNK, "0")
           field(INAM, "conditionInit")
           field(SNAM, "conditionProc")
           field(INPA, "$(device):CrntCmdAO PP")
           field(INPB, "$(device):CndtnLowLmtAO PP")
           field(INPC, "$(device):CndtnHighLmtAO PP")
           field(INPD, "0")
           field(INPE, "$(device):CndtnCyclTimeAO PP")
           field(INPF, "$(device):CndtnNmbrCyclsAO PP")
           field(INPG, "$(device):CndtnEndptAO PP")
           field(INPH, "1")
           field(H, "1")
           field(INPI, "$(device):CndtnModeBO PP")
           field(INPJ, "$(device):CndtnTimeStepAO PP")
           field(EGU, "")
           field(HOPR, "0")
           field(LOPR, "0")
           field(HIHI, "0")
           field(LOLO, "0")
           field(HIGH, "0")
           field(LOW, "0")
           field(PREC, "4")
           field(BRSV, "NO_ALARM")
           field(HHSV, "NO_ALARM")
           field(LLSV, "NO_ALARM")
           field(HSV, "NO_ALARM")
           field(LSV, "NO_ALARM")
           field(HYST, "0")
           field(ADEL, "0")
           field(MDEL, "0")
On 6/28/20 9:32 PM, Michael Davidsaver wrote:
CAUTION: *** EMAIL ORIGINATED FROM OUTSIDE THE ORGANIZATION. Please do not click links or open attachments unless you know the contents are safe. Verify that you recognize sender email address before clicking any link or attachment. DO NOT enter/change any password when clicking on a link. *** What does the record "T:Q03:CndtnSB" definition look like? Do you set INAM to "conditionInit"? On 6/28/20 5:10 PM, Ernesto Paiser via Tech-talk wrote:
Hello, My subroutine record (3.15.5) is not finding the INAM and the SNAM subroutines: iocInit() Starting iocInit ############################################################################ ## EPICS R3.15.5-01 ## EPICS Base built Feb 21 2020 ############################################################################ Subroutine not found PV: T:Q03:CndtnSB Init subroutine (INAM) The code was working in 3.14.11 (lised below): static long conditionInit(subRecord *psub) { struct myCallbackStruct *pcb; ... pcb->precord = psub; psub->dpvt = (void *)pcb; return(0); } static long conditionProc(subRecord *psub) { struct myCallbackStruct *pcb; long nRequest = 1; ... return(0); } static registryFunctionRef conditionRef[] = { {"conditionInit",(REGISTRYFUNCTION)conditionInit}, {"conditionProc",(REGISTRYFUNCTION)conditionProc} }; static void condition(void) { registryFunctionRefAdd(conditionRef,NELEMENTS(conditionRef)); } epicsExportRegistrar(condition); In the Makefile I have included the source code like below: # <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd $(PROD_IOC)_SRCS += $(PROD_IOC)_registerRecordDeviceDriver.cpp $(PROD_IOC)_SRCS_DEFAULT += iocshMain.c $(PROD_IOC)_SRCS += condition.c What I'm missing, is there some changes from 3.14.11 to 3.15.5. Thank you, Ernesto
Re: Sub record not finding INAM and SNAM Johnson, Andrew N. via Tech-talk
Sub record not finding INAM and SNAM Ernesto Paiser via Tech-talk
Re: Sub record not finding INAM and SNAM Michael Davidsaver via Tech-talk
Prev: ci-scripts 3.1 release: support for GitHub Actions Ralph Lange via Tech-talk
Next: Re: Sub record not finding INAM and SNAM Johnson, Andrew N. via Tech-talk
Prev: Re: Sub record not finding INAM and SNAM Johnson, Andrew N. via Tech-talk
