1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: [PV Access] Decimation Channel filter equivalent for PV Access?
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Juan F. Esteban Müller <JuanF.EstebanMuller at ess.eu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 1 Jul 2020 16:13:09 +0000
Was that a typo in your email or were you really asking pvmonitor for n:1 and not n:2?
- Andrew
On Jul 1, 2020, at 11:09 AM, Juan F. Esteban Müller via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Michael,
Thanks for your reply.
I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
This is my db file:
record(calc, "Test:counter") {
   field(INPA, " Test:counter")
   field(CALC, "A+1")
   field(SCAN, "1 second")
And I run it using softIocPVA.
If I do
camonitor 'Test:counter.{"dec":{"n":2}}'
I get every second update, while if I do
pvmonitor 'Test:counter.{"dec":{"n":2}}'
I get nothing. Funny enough, if I do
pvmonitor 'Test:counter.{"dec":{"n":1}}'
then I get every update...
I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
Cheers,
Juan
On 2020-07-01, 15:39, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
   On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
Hi all,
I would like to know if there is anything equivalent to the CA decimation filter in PV access.
https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
   These filters are implemented at the database level, and so work both with CA and PVA
   (via. the RSRV and QSRV server implementations).
Complexity comes for free, simplicity you have to work for.
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Next: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 01 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
