Subject: Re: DISP field in pvAccess
To: Michael Davidsaver <[email protected]>
Cc: [email protected]
Date: Thu, 2 Jul 2020 08:52:05 +0200
On Thu, Jul 2, 2020 at 12:06 AM Michael Davidsaver <[email protected]> wrote:
This is a bug.  Would you like to create a report?
https://github.com/epics-base/pva2pva/
On 7/1/20 2:46 PM, Saeed via Tech-talk wrote:
> Hi,
> I'm trying to use DISP field for disabling the remote puts to my PV. It works as expected when I use CA but it seems like the IOC is neglecting this field and actually write to PV when the put is issued from pvAccess.
> 'test' is an ao record without any fields set in DCT and I use EPICS R7.0.4 here.
>     ❯ caput test 10
>     Old : test                           0
>     New : test                           10
>     ❯ pvput test.DISP 1
>     Old : 2020-07-01 23:25:09.008  0
>     New : 2020-07-01 23:25:09.008  1
>     ❯ caput test 20
>     Old : test                           10
>     CA.Client.Exception...............................................
>         Warning: "Channel write request failed"
>         Context: "op=1, channel=test, type=DBR_STRING, count=1, ctx="test""
>         Source File: ../oldChannelNotify.cpp line 158
>         Current Time: Wed Jul 01 2020 23:25:34.720217912
>     New : test                           10
>     ❯ pvput test 20
>     Old : 2020-07-01 23:25:09.008  10
>     New : 2020-07-01 23:25:42.116  20
> Any thoughts?
> Thanks,
> Saeed
DISP field in pvAccess Saeed via Tech-talk
Re: DISP field in pvAccess Michael Davidsaver via Tech-talk
Prev: Re: DISP field in pvAccess Michael Davidsaver via Tech-talk
Next: FW: Opening opi/bob files into display mode from the terminal Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Next: Many EPICS Applications in Docker Images Philipp Klaus via Tech-talk
