Subject: Re: [PV Access] Decimation Channel filter equivalent for PV Access?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Juan F. Esteban Müller <[email protected]>
Date: Fri, 3 Jul 2020 07:46:47 -0700
On 7/1/20 11:21 AM, Juan F. Esteban Müller wrote:
> Thanks for the info. I don't fully understand the issue... Is there any workaround? Or in which cases the "dec" filter works?
I may have a fix.  Please test if you are able.
https://github.com/epics-base/pva2pva/pull/34
> Cheers,
> Juan
> On 2020-07-01, 18:22, "Michael Davidsaver" <[email protected]> wrote:
>     On 7/1/20 9:09 AM, Juan F. Esteban Müller wrote:
>     > Hi Michael,
>     > Thanks for your reply.
>     > I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
>     > This is my db file:
>     > record(calc, "Test:counter") {
>     >     field(INPA, " Test:counter")
>     >     field(CALC, "A+1")
>     >     field(SCAN, "1 second")
>     > And I run it using softIocPVA.
>     > If I do
>     > camonitor 'Test:counter.{"dec":{"n":2}}'
>     > I get every second update, while if I do
>     > pvmonitor 'Test:counter.{"dec":{"n":2}}'
>     > I get nothing. Funny enough, if I do
>     > pvmonitor 'Test:counter.{"dec":{"n":1}}'
>     > then I get every update...
>     > I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
>     Oh, right.  With the 'dec' filter you're seeing the effects of:
>     https://github.com/epics-base/pva2pva/issues/32
>     Specifically:
>     > QSRV assumes that the first DBE_PROPERTY update will never be dropped.
>     > If such an update is dropped, the subscription stalls.
>     I don't have a full solution to this yet.
>     Part of https://github.com/epics-base/epics-base/pull/71
>     includes a change to Base which will allow filters to distinguish
>     value and meta-data updates.  Of course this won't necessarily
>     help with older Base versions.
>     QSRV could also be changed to not wait for the initial meta-data
>     update.  The result would be a double initial update for most new subscribers.
>     There is nothing really wrong with this, I just found it annoying.
>     > Cheers,
>     > Juan
>     > On 2020-07-01, 15:39, "Michael Davidsaver" <[email protected]> wrote:
>     >     On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
>     >     > Hi all,
>     >     > I would like to know if there is anything equivalent to the CA decimation filter in PV access.
>     >     > https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
>     >     These filters are implemented at the database level, and so work both with CA and PVA
>     >     (via. the RSRV and QSRV server implementations).
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
Prev: how to acess variables in record field. Saurabh Srivastava via Tech-talk
Next: Cross-compile epics applicaton for debian 8 on the zynq 赵江 via Tech-talk
Prev: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Next: Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
