Hi Michael,
Thanks for the very quick fix!
The test I was doing before now works fine.
I'll be on holidays for the next two weeks, but after that I will do some more test.
Juan
On 2020-07-03, 16:56, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
On 7/1/20 11:21 AM, Juan F. Esteban Müller wrote:
> Thanks for the info. I don't fully understand the issue... Is there any workaround? Or in which cases the "dec" filter works?
I may have a fix. Please test if you are able.
https://github.com/epics-base/pva2pva/pull/34
> Cheers,
> Juan
> On 2020-07-01, 18:22, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
> On 7/1/20 9:09 AM, Juan F. Esteban Müller wrote:
> > Hi Michael,
> > Thanks for your reply.
> > I was suspicious, because I had the feeling I used it in the past... Can you maybe then give me a clue why I can't make it work in a simple example?
> > This is my db file:
> > record(calc, "Test:counter") {
> > field(INPA, " Test:counter")
> > field(CALC, "A+1")
> > field(SCAN, "1 second")
> > And I run it using softIocPVA.
> > If I do
> > camonitor 'Test:counter.{"dec":{"n":2}}'
> > I get every second update, while if I do
> > pvmonitor 'Test:counter.{"dec":{"n":2}}'
> > I get nothing. Funny enough, if I do
> > pvmonitor 'Test:counter.{"dec":{"n":1}}'
> > then I get every update...
> > I am using base 7.0.4, but I also tested 7.0.3.1, which is the one I used in the past when testing the filters.
> Oh, right. With the 'dec' filter you're seeing the effects of:
> https://github.com/epics-base/pva2pva/issues/32
> Specifically:
> > QSRV assumes that the first DBE_PROPERTY update will never be dropped.
> > If such an update is dropped, the subscription stalls.
> I don't have a full solution to this yet.
> Part of https://github.com/epics-base/epics-base/pull/71
> includes a change to Base which will allow filters to distinguish
> value and meta-data updates. Of course this won't necessarily
> help with older Base versions.
> QSRV could also be changed to not wait for the initial meta-data
> update. The result would be a double initial update for most new subscribers.
> There is nothing really wrong with this, I just found it annoying.
> > Cheers,
> > Juan
> > On 2020-07-01, 15:39, "Michael Davidsaver" <mdavidsaver at gmail.com> wrote:
> > On 7/1/20 2:59 AM, Juan F. Esteban Müller via Tech-talk wrote:
> > > Hi all,
> > > I would like to know if there is anything equivalent to the CA decimation filter in PV access.
> > > https://epics.anl.gov/base/R7-0/4-docs/filters.html#Decimation-Filter-dec
> > These filters are implemented at the database level, and so work both with CA and PVA
> > (via. the RSRV and QSRV server implementations).
- [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
- Re: [PV Access] Decimation Channel filter equivalent for PV Access? Michael Davidsaver via Tech-talk
- Re: [PV Access] Decimation Channel filter equivalent for PV Access? Juan F. Esteban Müller via Tech-talk
Re: Epics iocInit() Mark Rivers via Tech-talk
oagwish and sdds - tktable not found Ernesto Paiser via Tech-talk
<2020>
2025
ARM cross-built targets linux-arm_el and linux-arm_eb – last call Johnson, Andrew N. via Tech-talk
<2020>
2025
