1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: oagwish and sdds - tktable not found
From: Ernesto Paiser via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 5 Jul 2020 00:54:11 +0000
Hi guys,
I found the problem. I installed in tcl-tk in a different conda environment.
After removing and reinstalling in the correct current environment it worked.
Sorry for the noise.
 Ernesto
-----Original Message-----
From: Ernesto Paiser <ernesto_paiser at lynceantech.com>
Sent: Saturday, July 4, 2020 3:47 PM
To: tech-talk at aps.anl.gov
Subject: oagwish and sdds - tktable not found
Hello,
I'm having troubles with oagwish using the package Tktable (RedHat 8.2 - EPICS 3.15.5):
I've installed all SDDS set and TCL-TK following the instructions  in the webpage:
https://www.aps.anl.gov/Accelerator-Operations-Physics/Software/installationGuide_Linux
I have downloaded Tktable2.10.tar.gz, untar it and configured to make it with:
./configure --with-tcl=/usr/lib/lib64/libtcl --with-tk=/usr/lib/lib64/libtk make make install
# make install
 /usr/bin/install -c libTktable2.10.so /usr/lib/Tktable2.10/libTktable2.10.so
 : /usr/lib/Tktable2.10/libTktable2.10.so
 Install tkTable.tcl /usr/lib/Tktable2.10/tkTable.tcl  Install tktable.py /usr/lib/Tktable2.10/tktable.py /usr/bin/install -c -m 644 pkgIndex.tcl /usr/lib/Tktable2.10  Install license.txt /usr/lib/Tktable2.10/license.txt  Install README.txt /usr/lib/Tktable2.10/README.txt
But when I run oagwish:
[epics2@clsps01 TCL-TK 03:16:10] oagwish % package require Tktable can't find package Tktable %
Someone knows what is missing?
Thank you
 Ernesto
oagwish and sdds - tktable not found Ernesto Paiser via Tech-talk
Prev: oagwish and sdds - tktable not found Ernesto Paiser via Tech-talk
Next: Re: Re: Epics iocInit() fandayu--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Masking values in combo boxes Nonn, Patrick via Tech-talk
ANJ, 06 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
