Subject: Re: Re: Epics iocInit()
To: "Mark Rivers" <[email protected]>
Date: Mon, 6 Jul 2020 17:09:03 +0800
Hi Mark
     Firstly, thank you very much for you relpy.
Now I will answer your some question:
- It looks like this is Windows, correct?
 Yes, this is Windows
-  What does the error message say in English?
 the error message mean:There was a problem that caused the program to stop working properly.Please close the program
- What versions of EPICS base and other modules (asyn, etc.)?
 EPICS base ver:base-7.0.3.1  asyn ver:asyn-R4-37  busy ver: busy-R1-7-2 std-R3-6 .... and so on
- It looks like tucsen.com makes cameras.  Is this an areaDetector IOC?
 YES our campany makes cameras, I'm a software engineer from tucsen.
  • YES,this is areaDetector IOC We want to develop our camera on Epics software.
- What IOC application is it?  Is it one you wrote, or one you got from some EPICS module?
year I refer to ioc from Andor3
- Do you get any output in the IOC console before you get that error?  If the error is a missing DLL then you probably won't.
  • I added the necessary DLL files,So I think it should not be caused by DLL
- If you do get output then please send the complete output.
    • It crashes when it runs and there's no output, right
    • sometimes I find if i
      • Adding this function( createParam(TucsenPixelEncodingString,    asynParamInt32,   &TucsenPixelEncoding);
      • ) will cause the program to crash
      • In particular this enumeration(asynParamInt32
        • Could I trouble you for help,thk
Date: 2020-07-04 22:10
Subject: Re: Epics iocInit()
There is way too little information in your message to answer your question.  Most of the people on tech-talk cannot read Chinese so we don't know what the error message says.  But even if we did we need to know a lot more.
From: Tech-talk <[email protected]> on behalf of fandayu--- via Tech-talk <[email protected]>
Sent: Friday, July 3, 2020 12:31 AM
Subject: Epics iocInit()
hi
[cid:_Foxmail.1@ba3ab396-468b-e51a-e09a-1eb639df79e2]
The code crashes when it is iocInit() .Do you have any other good Suggestions
Re: Re: Epics iocInit() fandayu--- via Tech-talk
RE: Re: Epics iocInit() Mark Rivers via Tech-talk
Prev: RE: oagwish and sdds - tktable not found Ernesto Paiser via Tech-talk
Next: Re: Re: Epics iocInit() fandayu--- via Tech-talk
Prev: Re: Epics iocInit() Mark Rivers via Tech-talk
