1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Masking values in combo boxes
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 6 Jul 2020 18:33:40 +0200
On Mon, 6 Jul 2020 at 16:21, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
?  I have four options, and mbbo did the trick. May I assume, that this is the intended way to implement such options (At least up to 16)?
Yes.  If there are only 2 options you can also use the bo/bi records.
More modern terms for the concepts implemented in the digital EPICS records would be:
bi/bo:    Boolean
mbbi/mbbo:    Enum
mbbiDirect/mbboDirect:    Bitmask
longin/longout:    Integer
Cheers,
~Ralph
Masking values in combo boxes Nonn, Patrick via Tech-talk
Re: Masking values in combo boxes Jemian, Pete R. via Tech-talk
Re: Masking values in combo boxes Nonn, Patrick via Tech-talk
Fwd: Masking values in combo boxes Mark Rivers via Tech-talk
Prev: Fwd: Masking values in combo boxes Mark Rivers via Tech-talk
Next: Re: Masking values in combo boxes Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
ANJ, 06 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
