Subject: Re: Masking values in combo boxes
From: Maren Purves via Tech-talk <[email protected]>
Date: Mon, 6 Jul 2020 06:37:14 -1000
If you have more than 16 options you can use a calc record and more than one mbbo.
Maren Purves
East Asian Obsersvatory
On Mon, Jul 6, 2020 at 4:20 AM Mark Rivers via Tech-talk <[email protected]> wrote:
Forgot to CC tech-talk.
Sent from my iPhone
Begin forwarded message:
Date: July 6, 2020 at 9:01:32 AM CDT
To: "Nonn, Patrick" <[email protected]>, "Jemian, Pete R." <[email protected]>
Subject: RE:  Masking values in combo boxes
?  I have four options, and mbbo did the trick. May I assume, that this is the intended way to implement such options (At least up to 16)?
Yes.  If there are only 2 options you can also use the bo/bi records.
From: Tech-talk <[email protected]> On Behalf Of Nonn, Patrick via Tech-talk
Sent: Monday, July 6, 2020 9:00 AM
To: Jemian, Pete R. <[email protected]>
From: "Jemian, Pete R." <[email protected]<mailto:[email protected]>>
To: "tech-talk" <[email protected]<mailto:[email protected]>>, "Patrick Nonn" <[email protected]<mailto:[email protected]>>
Sent: Monday, 6 July, 2020 15:23:31
How many options do you have? The mbbo record does this for up to 16 choices.
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Nonn, Patrick via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Monday, July 6, 2020 8:16:19 AM
To: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>>
Subject: Masking values in combo boxes
I have a longout PV, which sets the behaviour of my underlying server. The options are codified as integers. Now I would like to have a combo box with strings to "mask" the numeric values in cs studio phoebus. Should this rather be implemented in the widget or should this be implemented in the EPICS server, and if the letter, how could it be done?
Patrick
Masking values in combo boxes Nonn, Patrick via Tech-talk
Re: Masking values in combo boxes Jemian, Pete R. via Tech-talk
Re: Masking values in combo boxes Nonn, Patrick via Tech-talk
Fwd: Masking values in combo boxes Mark Rivers via Tech-talk
Prev: Re: Masking values in combo boxes Ralph Lange via Tech-talk
Next: RE: Re: Epics iocInit() Mark Rivers via Tech-talk
Next: HiSLIP support(experimental) for asy/stream device. Noboru Yamamoto via Tech-talk
