Subject: RE: HiSLIP support(experimental) for asy/stream device.
To: "'[email protected]'" <[email protected]>
Date: Wed, 15 Jul 2020 21:22:44 +0000
Hi Noboru,
That looks very nice.  When you are happy with the driver you can just make a Pull Request and I will add it to asyn.
What types of devices have you been using that support the HiSLIP protocol?
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Noboru Yamamoto via Tech-talk
Sent: Monday, July 6, 2020 11:13 PM
To: [email protected]
Subject: HiSLIP support(experimental) for asy/stream device.
Dear members of EPICS community:
During the "Stay Home" period,  I wrote experimental HiSLIP driver for asyn/stream device support.  As I said, this is still in an experimental stage but it can read/write values to the device using SCPI commands over HiSLIP protocol. I tested it with EPICS
R7 on CentOS 8.
If you are interested in this software, please check the drvAsynHiSLIP directory in
	https://github.com/noboruatkek/asyn
This directory also include cPyHiSLIP software which provides a cPyHiSLIP module for Python.
cPyHiSLIP shares C++ program with drvAsynHiSLIP but does not have any dependency on EPICS. (cPyHiSLIP is built and tested on CnetOS8 and MacOSX 10.15).
Your comments and suggestions will be greatly appreciated.
Thank you,
Noboru Yamamoto
Accelerator Control group
J-PARC center/KEK & JAEA
web: http://www-acc.kek.jp/EPICS_Gr/default.html
HiSLIP support(experimental) for asy/stream device. Noboru Yamamoto via Tech-talk
Prev: RE: Modbus alarms question Mark Rivers via Tech-talk
Next: Re: SRQ over VXI Noboru Yamamoto via Tech-talk
Prev: HiSLIP support(experimental) for asy/stream device. Noboru Yamamoto via Tech-talk
Next: Question about running cs-studio/phoebus with Channel Archiver Elena Malanushenko via Tech-talk
