Subject: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway
Date: Fri, 17 Jul 2020 14:23:44 +0000
Hi Mark, thanks for your suggestions. I will give a final try during our maintenance days.
On 7/14/20, 8:03 AM, "Mark Rivers" <[email protected]> wrote:
    Hi Yong,
    > 2) I tried Mark Engbretson’s suggestion by putting an old slower speed hub in between our upgraded network hardware and this older device. In my case, the system becomes even slower;
    As I recall you said that it got slower when your network infrastructure was recently upgraded.  That suggests the problem could actually be related to the network.
    Here are 2 things I would try:
    1) Remove the network infrastructure from the setup completely for testing.  Plug the  E5810 LAN/GPIB Gateway directly into a dedicated NIC.
    2) Use tcpdump or wireshark to capture the traffic between the IOC and the Gateway both with the dedicated NIC and with the normal network configuration.
Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
RE: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
Prev: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Next: asyn R4-40 available Mark Rivers via Tech-talk
Prev: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Mark Rivers via Tech-talk
Next: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Michael Davidsaver via Tech-talk
