1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: Pure Python IOC (CAProcess issue)
From: Matt Newville via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Date: Fri, 17 Jul 2020 12:39:16 -0500
On Fri, Jul 17, 2020 at 11:56 AM Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 7/17/20 9:33 AM, Michael Davidsaver wrote:
> The python subprocess module shouldn't let this happen though since it does
> fork() and then execv(), and the situation which I describe is only possible
> if fork() is not followed by execv().
Oh wait.  CAProcess (which I've not seen previously) is using
the multiprocessing module, which can do fork() without exec().
In fact, this is the default on *NIX.  So this is likely or
problem.  I think you'll need to use the 'spawn' or 'forkserver'
method.
Well, CAProcess deletes the CA context and clears any cached CA data before the forked process runs so that the process will create and use its own CA context.
The problem actually reported happens when trying to create 25,000 unused CAProcesses, none of which did any real CA work.
But, sure, creating many CAProcesses from a CAThread to do work that might want to connect (each with their own CA context) to PVs might not be the wisest approach.  One could have separate worker processes running, ready to react to messages (perhaps from CA) to start some long-running work.
What I find most confusing is the fact that the program creates a CAThread from pycaspy write().  Some value in a python program changed and you want to send that to the outside world via CA (and are using pycaspy because you were too lazy to create a PV in a softIoc or this is all too dynamic to capture in a softIoc?) *and* you want to notify another thread in the same program that the value changed, and you decide that CA is the right way to send that message.   For communicating within a single process, you don't need CA at all.
--Matt
Re: Pure Python IOC (CAProcess issue) Michael Davidsaver via Tech-talk
Pure Python IOC (CAProcess issue) Simon Reiter via Tech-talk
Prev: Re: Pure Python IOC (CAProcess issue) Michael Davidsaver via Tech-talk
Next: Re: Pure Python IOC (CAProcess issue) Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: Re: Pure Python IOC (CAProcess issue) Michael Davidsaver via Tech-talk
ANJ, 17 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
