1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Network interruptions possible this week
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 21 Jul 2020 21:29:23 +0000
Argonne's network connections to the outside world are being upgraded starting from tomorrow, and this work may cause a few connectivity issues over the next few days. If you find you are unable to connect to the EPICS website at Argonne later this week, please try again later, or try the epics-controls website instead. We have been told there should be few if any interruptions though, and that any that do occur should be brief.
Some posts to the tech-talk and core-talk lists might get held up for a while in a queue, but email messages are almost never lost during this kind of maintenance so please don’t re-send them unless you get an explicit notification that your message could not be delivered and that your sending agent has given up (which usually takes 2-3 days).
- Andrew
Complexity comes for free, simplicity you have to work for.
Prev: Re: TCP to LabVIEW TCP VI using Stream Device. Mark Rivers via Tech-talk
Next: Re: TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: [EXTERNAL] Assign actions to Combobox items in Phoebus Kasemir, Kay via Tech-talk
Next: database method to copy string to char waveform Malte Gotz via Tech-talk
ANJ, 22 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
