Subject: Changing Asyn Port Driver paramList dynamically
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Thu, 23 Jul 2020 03:16:11 +0000
Hello.
I have this class inheritance scenario:
asynPortDriver <- fatherClass <- childClass
fatherClass constructor is calling asynPortDriver constructor, informing the number of elements of paramList as well as masks for interfaces used.
I’d like childClass to add more parameters to paramList after fatherClass already created this list and, eventually, add interfaces to the Asyn mask.
Is it possible?
Thank you,
Márcio Paduan Donadio
Control Systems Engineer - SLAC
Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
Prev: Re: Changing ioc logging. Should I use a modified iocLogServer? Johnson, Andrew N. via Tech-talk
Next: AW: database method to copy string to char waveform Malte Gotz via Tech-talk
Next: Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
