Subject: AW: database method to copy string to char waveform
To: "EPICS tech-talk" <[email protected]>
Date: Thu, 23 Jul 2020 06:47:04 +0000
Title: AW: database method to copy string to char waveform
Thank you Mark, Ralph and Andrew,
the lso record works perfectly! I wasn't aware it existed in 3.15.
I couldn't get Marks's suggestion to use
field(OUT,"$(X)netCDF1:FileName.VAL$ CA")
in the scalout to work, but didn't try very hard, because the lso record does exactly what I need.
Cheers
Malte
-----Ursprüngliche Nachricht-----
Von: Johnson, Andrew N. via Tech-talk <[email protected]>
Gesendet: Mittwoch 22 Juli 2020 17:35
An: EPICS tech-talk <[email protected]>
Betreff: Re: database method to copy string to char waveform
You can also use a long string output (lso) record to copy a string into a waveform or vice versa. This works for me, and will similarly require 3.15 or later:
record(stringout, "so") {
  field(VAL, "This is another string")
record(waveform, "wf") {
  field(NELM, 100)
  field(FTVL, CHAR)
record(lso, "xerox") {
  field(DOL, "so")
  field(OMSL, "closed_loop")
  field(OUT, "wf")
You can swap the DOL and OUT links to copy in the other direction.
- Andrew
On Jul 22, 2020, at 9:19 AM, Ralph Lange via Tech-talk <[email protected]> wrote:
Hi Malte,
Using current 3.15 or EPICS 7, this database:
record (waveform, "wf") {
  field(NELM, "100")
  field(FTVL, "CHAR")
  field(INP, "so.VAL$")
record (stringout, "so") {
  field(VAL, "this is a string")
does that job for me. Or did I get the problem wrong?
Cheers,
~Ralph
Complexity comes for free, simplicity you have to work for.
Prev: Changing Asyn Port Driver paramList dynamically Paduan Donadio, Marcio via Tech-talk
Next: How to check IOC connection Jong Woo Kim via Tech-talk
Prev: Re: Changing Asyn Port Driver paramList dynamically Lucas Russo via Tech-talk
