1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: cs-studio linux version that works with archiver
From: astrid morreale via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Thu, 30 Jul 2020 07:49:26 -0600
Hello,
In my attempt to retrieve archived data with a viewer (other than archiver viewer) I downloaded two different  linux 4.3 versions of  cs-studio from here:
and I have  tried following using the instructions in https://slacmshankar.github.io/epicsarchiver_docs/csstudio.html .
However the last two cs-versions versions I downloaded are missing essential things like  the trend tab (and thus I cannot add my pbraw::... retrieval)
Could someone recommend a pre-compiled version of cs-studio that works with the archiver, or point me to the plugins etc that the generic cs studio is missing?
I did check that the sns-css version of cs-studio has the trend tabs but then it is heavily configured for sns operations.
kind regards and thanks in advance
Astrid
Astrid Morreale
Staff Scientist Subatomic Physics Group.
Los Alamos National Laboratory.
astrid at lanl.gov
Re: cs-studio linux version that works with archiver Lucas Russo via Tech-talk
Prev: RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Re: cs-studio linux version that works with archiver Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: EPICS Base Compilation Failed Under Cygwin gcc 9+ Johnson, Andrew N. via Tech-talk
ANJ, 03 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
