Hi Astrid, We, at LNLS, are using the ESS version available here, but others should work just fine: https://artifactory.esss.lu.se/artifactory/CS-Studio/production/4.6.1.25/ You can manually change the Databrowser settings (and others) by either: 1) editing the file "configuration/plugin_customization.ini" inside the CS-Studio installation directory, like this: # Data Browser # Removal of these settings results in empty defaults # URLs to suggest in the "Archives" view org.csstudio.trends.databrowser3/urls=pbraw://10.0.38.42/retrieval|LNLS Archiver org.csstudio.trends.databrowser3/use_auto_scale=true org.csstudio.trends.databrowser3/plot_bins=10 org.csstudio.trends.databrowser3/request_type=RAW # Default data sources for newly added channels # Format: <name>|<key>|<url> # xnds: URLs use the key. Other URLs might ignore the key. org.csstudio.trends.databrowser3/archives=LNLS Archiver|1|pbraw://10.0.38.42/retrieval org.csstudio.trends.databrowser3/use_default_archives=true 2) inside CS-Studio by going to "edit -> preferences -> CSS Applications -> Trends -> Data Browser" If you are familiar with Ansible you can look at our CS-Studio role that should install everything you need with your custom settings: https://github.com/lnls-sirius/lnls-ansible/tree/master/roles/lnls-ans-role-cs-studio The archiver variables for databrowser are the ones located here: https://github.com/lnls-sirius/lnls-ansible/blob/master/roles/lnls-ans-role-cs-studio/defaults/main.yml#L32 Hope this helps, Cheers! Lucas On Thu, Jul 30, 2020 at 10:54 AM astrid morreale via Tech-talk <tech-talk at aps.anl.gov> wrote:
ANJ, 30 Jul 2020 |
![]() · Search · EPICS V4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
