Subject: Re: looking for aai/waveform example
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 31 Jul 2020 11:33:41 +0200
For the record:
Using a recent version of EPICS Base, you can also avoid copying and swap pointers instead.
See How To Avoid Copying Arrays with waveformRecord in the EPICS How To pages.
In this specific case (shared memory involved) copying might be preferred, though.
Cheers,
~Ralph
On Thu, 30 Jul 2020 at 23:51, Hu, Yong via Tech-talk <[email protected]> wrote:
Hi Dave,
For waveform record, I usually simply use “memcpy” in the device support routine, something like this:
    memcpy(precord->bptr, pointer-to-data-source, size-of-bytes-to-be-copied);
    precord->nelm = number-of-data-point;
precord->nord = number-of-data-point;
precord is a pointer to waveformRecord.
Good luck!
Yong
looking for aai/waveform example David A. Slimmer via Tech-talk
Re: looking for aai/waveform example Hu, Yong via Tech-talk
Prev: Re: looking for aai/waveform example Hu, Yong via Tech-talk
Next: Re: Attocube IDS3010 Bradnick, Ben (DLSLtd, RAL, LSCI) via Tech-talk
Next: EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
