1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: can't find pydm widget
From: Hugo Slepicka via Tech-talk <tech-talk at aps.anl.gov>
To: "Lorelli, Jeremy J" <lorelli at slac.stanford.edu>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 10 Aug 2020 08:18:46 -0700
Hi Geyang,
I see that you are using also Anaconda.
Please make sure that your Qt and PyQt are coming from conda-forge and not from defaults.
There is a bug with their recipe that I addressed but they did not yet pulled the patch.
If Jeremy’s solution didn’t work, please send me the output of:
conda list | grep qt
conda list | grep pydm
Cheers,
Hugo
On Mon, Aug 10, 2020 at 12:22 AM Lorelli, Jeremy J via Tech-talk <tech-talk at aps.anl.gov> wrote:
Hi Geyang,
I had a similar problem when installing pydm initially. An easy fix is to create a file called designer_plugin.py with the following code in it:
from pydm.widgets.qtplugins import *
Then point PYQTDESIGNERPATH to the directory where this file is located.
Best,
Jeremy L.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Silver via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, August 10, 2020 12:06 AM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: can't find pydm widget
hi,
As the steps in https://slaclab.github.io/pydm/installation.html, I used Miniconda to install the software. When I run designer(QT5), I can't find pydm widget in GUI.
I try to add environment variable as: "export PYQTDESIGNERPATH=/home/iocusr/miniconda2/envs/pydm-env/lib/python3.6/site-packages/pydm/"
it didn't work. can anyone give me some suggestions? Thanks a lot.
Best wishes
Geyang 2020-08-10
can't find pydm widget Silver via Tech-talk
Re: can't find pydm widget Lorelli, Jeremy J via Tech-talk
Prev: EpicsWiki Update for EPICS 7.x Ivo Hanak via Tech-talk
Next: Re: HDF5 client for EPICS 3.15 Shen, Guobao via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: can't find pydm widget Lorelli, Jeremy J via Tech-talk
Next: EpicsWiki Update for EPICS 7.x Ivo Hanak via Tech-talk
ANJ, 10 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
