1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: can't find pydm widget
From: "Lorelli, Jeremy J via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>, Silver <marco_hair at 163.com>
Date: Mon, 10 Aug 2020 07:21:46 +0000
Hi Geyang,
I had a similar problem when installing pydm initially. An easy fix is to create a file called designer_plugin.py with the following code in it:
from pydm.widgets.qtplugins import *
Then point PYQTDESIGNERPATH to the directory where this file is located.
Best,
Jeremy L.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Silver via Tech-talk <tech-talk at aps.anl.gov>
Sent: Monday, August 10, 2020 12:06 AM
Subject: can't find pydm widget
hi,
As the steps in https://slaclab.github.io/pydm/installation.html, I used Miniconda to install the software. When I run designer(QT5), I can't find pydm widget in GUI.
I try to add environment variable as: "export PYQTDESIGNERPATH=/home/iocusr/miniconda2/envs/pydm-env/lib/python3.6/site-packages/pydm/"
it didn't work. can anyone give me some suggestions? Thanks a lot.
Best wishes
Geyang 2020-08-10
Re: can't find pydm widget Hugo Slepicka via Tech-talk
can't find pydm widget Silver via Tech-talk
Prev: can't find pydm widget Silver via Tech-talk
Next: EpicsWiki Update for EPICS 7.x Ivo Hanak via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: Re: can't find pydm widget Hugo Slepicka via Tech-talk
ANJ, 10 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
