Hi Andrew,
This worked!
and followed the simple instructions.
then my gateway worked.
thanks, everyone for a quick response!
Vivian
On Aug 27, 2020, at 4:40 PM, Johnson, Andrew N. < anj at anl.gov> wrote:
Hi Vivian,
On Aug 27, 2020, at 1:23 PM, Vivian O'Dell via Tech-talk < tech-talk at aps.anl.gov> wrote:
I
get the same error message with more recent versions of ca-gateway as well. I'm using EPICS 3.15.7.
This version of gateway compiles fine on the beagle bone. Is there an obvious fix for this?
I get the same errors as you on Mojave; after some investigation I assume there’s something in the Linux (glibc) implementation of regex.h which gateway is using that isn’t present in Apple’s version, so the header exists but doesn’t define those
structures.
A fix that works for me is to switch to using PCRE; there’s a configuration option you use to do that:
diff --git a/configure/CONFIG_SITE b/configure/CONFIG_SITE
index 5dee672..8588491 100644
--- a/configure/CONFIG_SITE
+++ b/configure/CONFIG_SITE
@@ -13,7 +13,7 @@
# Use Perl compatible regular expressions (PCRE) instead of basic regex
-#USE_PCRE=YES
+USE_PCRE=YES
# For PCRE on Linux
# requires package pcre-devel (or libpcre3-dev) for compiling
My version of pcre seems to be from homebrew. I’m not sure what installed it but there are probably a few versions available that should work if you don’t have that. There are some configuration variables that follow the USE_PCRE setting in the
above file that you might have to fiddle with, but hopefully this will get you going again.
- Andrew
Complexity comes for free, simplicity you have to work for.
- error trying to compile ca-gateway on macOS mojave Vivian O'Dell via Tech-talk
- Re: error trying to compile ca-gateway on macOS mojave Johnson, Andrew N. via Tech-talk
Re: error trying to compile ca-gateway on macOS mojave Vivian O'Dell via Tech-talk
PTP hardware timestamps in EPICS facilities Frank, William (STFC, RAL, ISIS) via Tech-talk
<2020>
2025
<2020>
2025
ANJ, 28 Aug 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
