1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: RTEMS/MVME2100 OMS58 card does not exist! error
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: 'Ralph Lange' <ralph.lange at gmx.de>
Cc: "tech-talk at aps.anl.gov \(tech-talk at aps.anl.gov\)" <tech-talk at aps.anl.gov>
Date: Fri, 11 Sep 2020 16:28:19 +0000
Hi Michael,
Ø  You have to find out their addresses under RTEMS and adapt the arguments to the driver setup call in your st.cmd accordingly.
I don’t think that is true, the driver hides that by mapping the VME address (which should be the same on vxWorks and RTEMS) to the CPU address.
The current master branch of drvOms58.cc contains this:
#ifdef vxWorks
            status = devRegisterAddress(__FILE__, OMS_ADDRS_TYPE,
                                        (size_t) probeAddr, OMS_BRD_SIZE,
                                        (volatile void **) &localaddr);
            Debug(9, "motor_init: devRegisterAddress() status = %d\n", (int) status);
            if (!RTN_SUCCESS(status))
                errPrintf(status, __FILE__, __LINE__, "Can't register address 0x%x\n",
                          (unsigned int) probeAddr);
                return(ERROR);
#endif
So it uses devLib to map the VME address (from the startup script) to a local CPU address.  That should make the startup script OS-independent.  But notice that this is in an ifdef for vxWorks.
There is a recent pull request to remove that vxWorks dependency.  Which version of the code you are running?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Ralph Lange via Tech-talk
Sent: Friday, September 11, 2020 11:13 AM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Re: RTEMS/MVME2100 OMS58 card does not exist! error
The different VME address spaces are being mapped into the address space of the CPU through different "address windows".
While the same jumper setting will have each card at the same location in the VME address space, the mapping into the CPU address space is different between RTEMS and VxWorks.
Cheers,
~Ralph
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
RTEMS/MVME2100 OMS58 card does not exist! error Sintschuk, Michael via Tech-talk
Re: RTEMS/MVME2100 OMS58 card does not exist! error Ralph Lange via Tech-talk
Prev: Re: RTEMS/MVME2100 OMS58 card does not exist! error Ralph Lange via Tech-talk
Next: AW: RE: Has anyone written an IOC for control of (PI)Acton spectrometers? Joern Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
ANJ, 11 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
