1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: AW: RE: Has anyone written an IOC for control of (PI)Acton spectrometers?
From: Joern Dreyer via Tech-talk <tech-talk at aps.anl.gov>
To: "'Heesterman, Peter J'" <Peter.Heesterman at ukaea.uk>, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 11 Sep 2020 21:18:37 +0200
as these spectrometers use a simple command set that is described in a document by PrincetonImszruments, a simple StreamDevice protocol file can be written to control these devices.
I have done that but currently do not have access to the file. Can send it on monday.
Regards Jörn
---- Mark Rivers via Tech-talk schrieb ----
I am not aware of a driver for PI-Acton spectrometers other than ADLightField.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Heesterman, Peter J via Tech-talk
Sent: Friday, September 11, 2020 10:54 AM
To: EPICS Tech-Talk <tech-talk at aps.anl.gov>
Subject: Has anyone written an IOC for control of (PI)Acton spectrometers?
If the answer is no, I will be likely to write one.
I note this question touches on the discussion at https://epics.anl.gov/tech-talk/2019/msg00470.php.
I’m aware that ADLightField could be used to operate both Princeton cameras, and Acton spectrometers.
But we often use the spectrometer with cameras other than Princeton - and would prefer to use the ADPICam camera driver, if we are.
Many thanks,
Peter.
Peter Heesterman
Software Engineer
CODAS & IT
Providing services on behalf of United Kingdom Atomic Energy Authority
Culham Science Centre, Abingdon, OX14 3DB, UK
Tel. +44 1235 465157
Email: Peter.Heesterman at UKAEA.uk
Section mail address: PCDatanet-Support at ukaeauk.onmicrosoft.com
The content of this email is confidential and intended for the recipient specified in the message only. It is forbidden to share any part of this message with any third party, without the written consent of the sender. If you received this message by mistake, please reply to this message and then delete it, so that we can ensure it does not occur in the future.
Has anyone written an IOC for control of (PI)Acton spectrometers? Heesterman, Peter J via Tech-talk
RE: Has anyone written an IOC for control of (PI)Acton spectrometers? Mark Rivers via Tech-talk
Prev: RE: RTEMS/MVME2100 OMS58 card does not exist! error Mark Rivers via Tech-talk
Next: Re: RTEMS/MVME2100 OMS58 card does not exist! error Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: RE: Has anyone written an IOC for control of (PI)Acton spectrometers? Mark Rivers via Tech-talk
Next: RTEMS/MVME2100 OMS58 card does not exist! error Sintschuk, Michael via Tech-talk
ANJ, 11 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
